some opinions please
Old Oct 19, 2003 | 12:27 AM
Walter's Avatar
Im as loyal as my options
Default some opinions please
i was thinking about doing the mini me swap i have a 1990 civic std 4 speed i was going to do the dpfi yo mpfi and do the mini me sawp i have heard bad and good things about this what do you all think is best i heard it over heats then i heard it ran good all help is deeply appreciated
Old Oct 19, 2003 | 07:55 AM
KJ's Avatar
KJ
bored at work
Thing to consider. The civic 4spd is the STD model. It has an 8 valve head. Honda has made some 8 valve heads over the years the crx hf, civic STD and the civic cx. Some of these 8 valve blocks have pistons with only 8 valve reliefs. Some have the same pistons as the 16 valve dx heads. It realy just depends on the year. If you have a block with only 8 valve reliefs then you can't swap a 16 valve head on because the valves will smack the pistons. Just something you may want to look into.
Also I'm not personally a believer in the mini me swap so I'd either save up for a b16a or get a complete d16z6/y8 motor and wire the car up to obd1 so you can run the right ecu (P2 and distributor.
Old Oct 19, 2003 | 09:36 AM
Walter's Avatar
its a 16 valve head its basically the dx but 4 speed 1.5
blah blah blah
Old Oct 19, 2003 | 09:43 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
do what you can to get a "B" series motor into it, you will get quickly bored with a mini-me
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
Old Oct 19, 2003 | 08:03 PM
zexyintegra's Avatar
Going from dual point to multi is pain but have seen it done. If going mini me swap. Good get everything and don't cut coners. Don't spend money on a b-series go turbo with extra money. Much fast in the end? Besides You could get a cam and ported head and make 160 whp na
Rubbin's Racin'
