What's the Problem?
Old Oct 18, 2003 | 05:26 PM
BitbyStreetRacin's Avatar
once your bit, your done.
Default What's the Problem?
my b16a got fucked up. dont ask. but it was boggin down and not makin much power so i parked it for the night and the next morning, it barely started and died alot. took off the valve cover, and theres oil in a couple of the plug holes, not alot, but its there. i get it out and put the valve cover back on. now it doesnt start at all. took out the plugs and theyre black wet with oil. cleaned them off and put them back in and tried to start it. repeated that about 2 times and there was oil still. there also is a oil leak coming from here right in the middle of the pic; where the head and block come together on the bottom right corner. what could be wrong with this thing? never over-revved or mistreated it or anything so what could be the matter here? any advice would help alot. thx.
Old Oct 18, 2003 | 05:29 PM
Josh's Avatar
Dr. Doom
looks like headgasket.
Old Oct 19, 2003 | 07:15 AM
could it come from overfilling the oil?
Old Oct 19, 2003 | 07:48 AM
KJ's Avatar
KJ
bored at work
yeah over filling your oil can blow out a bunch of seals. My advice would be to clean your engine really well and then run the engine and look for where the oil is coming from. If you can't see it that way clean the engine again and let it dry. Throw baby powder on the engine in any areas that you think may be leaking or where oil is accumulating. The baby powder will stick and make a mess but as you drive and the oil leaks it will leave a very clear path through the baby powder and you will be able to see where it is coming from.
Old Oct 19, 2003 | 07:52 AM
99B16Si's Avatar
do a compression test also
Old Oct 19, 2003 | 08:52 AM
well i tried again and the plugs actually stayed dry this time, i just need to get new plugs to know if itll work now.
Old Oct 19, 2003 | 08:54 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
If it's a headgasket your oil will look milky. It could be your plug seals on the valve cover also, change those out.
Old Oct 19, 2003 | 10:39 AM
well im gonna go ahead and change the headgasket i guess. couldnt hurt. unless i can trade a stock good running b16 for my built head shitty running b16
