resistor box install
Old Oct 16, 2003 | 11:23 AM
Greddyboostedcivic's Avatar
H.I.D. has no cure
Default resistor box install
ive read a shit load of instructions on how to install these but im still a little confused... ok the box has 5 wires (4 black and 1 red) i know that the four black ones go to the injectors but where does the red one go? can i connect it to any of the yellow/black wires in the connector (the one in the pick) or is there a specific one i have to connect it to?
Old Oct 16, 2003 | 12:18 PM
xatracing's Avatar
dude... hers what you do.
do a continutiy test from that plug to the injectors. find the four wires that go to the injectors. this is your constant ignition power (+bat). remove 3 of them from the clip and cut off the fourth one, leaving a few inches of wire off the plug.
take your 4 wires that are going to the injectors and run them to the 4 black wires coming out of the reistor box. it doesnt matter the order, its constant power.
now, the one wire you left in that plug with extra lentgh, run THAT wire from the plug to the red wire on the resistor box. this will supply power through the resistor and out the black wires.
if you have any questions, gimme a call at XAT Racing
813.875.RACE(7223)
Taylor
