Code 9 . .
Old Oct 13, 2003 | 12:53 PM
civicracer901's Avatar
B16ACRX
Default Code 9 . .
Does anyone have any other ideas what to check on a code nine on b16A in a 88si crx. Just rewired the engine harness. hooked up vtec wires. All wiring is done correctly It has a ls Dis. we swap distributors from a b16 with a b16 distributor works fine. but still code nine. And if the motor is throwing a code with vtec engage? Its hooked up on a switch for now. Its a auto ecu but we swaped a 5spd ecu still the same code. Is there anything else to check or do?
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Oct 13, 2003 | 02:55 PM
KJ's Avatar
KJ
bored at work
So it has the same code on different distributors? Try switching the grn/yel with the grn/blu wire on the distributor plug engine harness side. Check for continuity from those wires to their spots at the ecu.
Blu/grn to c1
Blu/yel to c2
Those two pinouts are off the top of my head but I think they are right, check in a manual.
Old Oct 13, 2003 | 06:47 PM
B16ACRX
that might just work, I'll let you know. Or maybe tommorw I can come by the shop and have you look at it and pick up a tps.
Old Oct 13, 2003 | 07:26 PM
KJ's Avatar
KJ
bored at work
I won't be around the shop tomorrow, going to Spring Hill to work on some stuff.
Old Oct 15, 2003 | 04:45 PM
B16ACRX
You think Friday would be a good day to stop at your shop. I know I keep tryiing to get up there but Friday I have nothing going on. So iam postive I can stop up there.
Old Oct 15, 2003 | 04:46 PM
B16ACRX
I still need the tps sensor.
