axel
axel
what aaxel do i need for b16a in a crx hf everyone tells me something different i need to know if i can just go to auto zone or something and just buy one with out it bein custom put together thanks
DJ is right... 90-93 Integra axles work. I replaces some (and I need to again ) in my EF hatch with a B16... I went to Discount Auto and asked for 90-93 Integra LS axels and I got them, and they work.
90-93 teg axles work if you have an s1 intermediate shaft. These come on all 90-93 usdm tegs and also the integra xsi (b16a powered) 90-93 cars. The y1 intermediate shaft that came out of the 89-91 jdm sir's uses a different axle set since it is slightly longer. If you have this one you need a 86-89 teg axle w/ a 90-93 teg inner joint for the drivers side axle. Alot of the b16a1 that are sold came from the xsi's.
So figure out what intermediate shaft you have and then get the corresponding axles. BTW the jdm sir axles are exactly the same as the 86-89 teg's if you put the 90-93 inner joint. That is how Honda of Japan made them. Raxles and some of the other aftermarket axle manufactureres make these axles.
engine building &best
on
you can Use all 90+integra axels but if you go with 94+ you also must use the 94-01integra or 99-00civicSi inter.Shaft but as for the passanger side i would stick with 90-93 integra Ls
i love AUTOZONE
i love AUTOZONE
