Crvtec ????
Old Oct 8, 2003 | 02:11 PM
T61turboII's Avatar
Default Crvtec ????
I was just wondering if i could supercharge a crv with a gsr head...And if so how charger should i go with...What are the pros and cons of doing this....Any help or suggestions would be appreciated thanx.
Old Oct 8, 2003 | 02:33 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Read as much as you can. If you do this you will need to sleeve the block, and you would want to use forged internals. It is a hard combo to make work. www.crvtec.com check that place out. Oh yea i hope you have some DEEP pockets.
Old Oct 8, 2003 | 03:32 PM
pressuredsol's Avatar
Pleasure the do me
Well...you could keep the internals stock, under the stock boost. Superchargers are not high on the list of honda/acura mods. Search some for the pros and cons of s/c. You will find traction is the largest down fall to that particualar form of forced induction. If anything, go Vortec.
Old Oct 8, 2003 | 03:41 PM
T61turboII's Avatar
Thats what charger i was into looking at.. I would also be doin hondata at the same time... I dont plan on running much boost, but if it came down to it I would sleeve it and do all forged inside i have a guy that hooks me up with the internal work so thats not a big issue for me
Old Oct 8, 2003 | 03:45 PM
The sleeves will crak either way, even NA they crack. It WILL NEED to be sleeved.
