b series pressure plate?
Old Oct 6, 2003 | 07:03 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
Default b series pressure plate?
ok here we go. im using a stage 4 act clutch with an oem ls pressure plate in my car. would there be a difference if i put a act pressure plate or maybe even a type r pressure plate? it grabs pretty good now but i know it can grab better than it is. would it make a differnece?
tamparacing.com
Old Oct 6, 2003 | 08:08 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
which would be a better buy? ITR or ACT?
tamparacing.com
Old Oct 6, 2003 | 08:17 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
thanks for the flywheel reminder. it totaly sli[ped my mind
tamparacing.com
Old Oct 6, 2003 | 03:01 PM
Sunrise City Rider's Avatar
WHAT!?! OK!......
The Pressure plate is the clamping part of the clutch, the clutch disc is the floating disc that the pressure plate presses up against the flywheel...
The stronger the pressure plate, the harder the clutch will grab...
The materials that the clutch disc is made of will determine the amount of friction the pressure plate will apply to the flywheel...Higher Friction Materials like Ceramics and Sintered Iron are known to wear faster than Organic Materials because they create a higher friction pad and are much more aggressive...
DSM's and other AWD Drag Cars use a 2600lb Pressure Plate with a stock organic Clutch Disc to get the clamping force they need with as minimum amount of stress as possible...
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old Oct 6, 2003 | 05:51 PM
GOTTI's Avatar
OEM Parts Specialist
listen to the boys( zee and chronic)...they know what they are talking about...
