swap question
OEM Parts Specialist
on
swap question
what a/c and alt belt do you ise for a bseries swap in a EG. I ued the b series belts but theyu didn't work...also the d series doesn't work either
just take a piece of string and wrap it around the path of the belt then measure the length of the string and how many ribs are on the belt, then you can go to autozone, discount, or where ever with the length and rib count and they will find one to your specifications
Semper Fi
Aim and Yahoo- Inkedupordie
Semper Fi
on
ok cool..thanks...yea i am using the stock compressor..the a/c belt from the d series motor works on the alternator...so now i need to find the a/c belt..i'll try the string method
Yeah, Belts are only different in 2 areas, Length and Number of Ribs...
Do the string method and you get the right length...Ask for the belt for the component you need it for and you count the ribs, then just get the belt with that number of ribs with the length of the string...
Zee
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
