How to break OEM welds
Old Sep 29, 2003 | 11:22 PM
Gorky_Park's Avatar
Default How to break OEM welds
Just like it says, I'm trying to find out on how to break the OEM welds. What I'm trying to do is to take my old radiator support. It's all welded together. Someone told me you have to drill 'em out. Is it true? Can anyone on here do it for me?(For money, of course). Thanks.
Also, how much does the new painjob cost?
Thanks a lot.
Old Sep 30, 2003 | 12:21 AM
Civic11s's Avatar
Hey cronic you do have to drill them out, they are actually called spot welds. . . . . You do not want to take a Plasma or Sawzaw to them.. . . . . . . . . . . Just a drill will work. . . . . .I have the 94 civic11s for sale and I grafted the 98 front end on I went threw the trouble already (real pain in the asses). . . . . . hope I was of help to ya. . .later
Old Sep 30, 2003 | 12:22 AM
Civic11s's Avatar
oops I meant gorky parky not cronic, my bad. . . ..
Old Sep 30, 2003 | 02:39 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
grinder dude, welds are going to be a bitch to drill through, they will be harder than the actual steel itself.
Old Sep 30, 2003 | 02:40 AM
And plasma will definitely work, if you have one powerful enough, the one i have access to can cut up to 3/8s.
Old Sep 30, 2003 | 05:43 PM
xxlmadhatterlxx's Avatar
My Honda is slower
if its a spot weld you can drill it out.if it was weleded along the seams(tig or mig) you will need to use a plasma cutter or sawsall.If it is a pain in the ass go to a welding shop and they will probably just charge you there minimum fee.
Anyone want to buy 92-95 civic si parts? let me know ive got a lot of shit to get rid of.
Old Sep 30, 2003 | 05:50 PM
Get a fucking grinder. Also, you can spot weld with a mig or tig, all it is is welding one SPOT. What you seem to be talking about is stick welding (arc welding). Welding along the "seams" is called stitch welding.
Old Sep 30, 2003 | 06:15 PM
Durdan's Avatar
No Ants Drift Member
i have a spot weld cutter. it takes 1 minute per weld
drill pilot hole
use spot weld cutter
peaces fall apart and are reusable unlike using a torch or sawzall.
the spotweld cutter was my friend for my RHD conversion
RIP Tim. i miss you, buddy
