Power to weight Ratio? how?
Originally posted by Cronic
94 teg's weigh around 2500lbs.
power to weight = weight / power ( which gives you weight to power ratio )
Guest
Posts: n/a
Zee, we're of course assuming the ratios are the same, aerodynamics also play a great role as speeds increase... but again, we're not getting that indepth.
15.4:1 IE, 15.4lbs to every whp.
That is a pretty decent p/w ratio.
My Civic had a 16.6:1 ratio. She was a porky bitch. @ 2615lbs.
From what I read your friend's Teg weighs 2643lbs.
Now at 146.7whp and 2643lbs... we get.
2643/146.7
18.016:1 Weight to power ratio.
Not nearly as good as yours IF you have the same whp as him. You would dominate his car.
2643/146.7
i always dominate his car. not bragging or anything but it always happends. so basically divide power and weight. so i take it as the higher the # the better?
tamparacing.com
yea but i want to be a bit different. how would you feel if a 13 year old family CIVIC passes you up. its priceless. everyone has rex's and hatch's.
tamparacing.com
