using hondata with all motor??
Guest
Posts: n/a
what kinds of gains have people received when having the handata install and tuned on a all motor b-series. looking at getting it done but i want to see what kind of gains are people seeing. thanks in advance
I know this might be a little of course to your acutal questions but I wanted to share some insight...I was going to go the same route, but was advised that it wouldnt be too benefical for my particular setup. Reason being is that with the hondata setup(now, im no hondata guru mind you)that you will pay "x" amount of dollars to purchase the system then "xx" amount per "x" hours of dollars to have it tuned the 1st time around. Well, if you go with the alternative route (v-afc, etc)you will pay for the system "x" dollars, then maybe "x" of dollars to have it tuned PLUS maybe learn alittle about tuning it yourself, then you wont have to pay for dyno time hours and tuning if you change your setup ie, add more fuel, more parts, yada yada. Thats what was suggested to me for running all-motor. But of course, IF you had the cheese to pay for tuning when you upgrade, then by all means.
But I would like to know more info on running hondata as far as the gains/advantages myself.
cronic has a dyno graph which shows a 12 or 16 HP gain on a stock honda....stock......cant remember, i belive it was a dohc vtec
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
Guest
Posts: n/a
7h3 0|\|ly 7h1|\|g 4b0u7 H0|\|d474 15 7h47 b3c4u53 17'5 50 4dv4|\|c3d, 17 74k35 4 b17 70 7u|\|3. C4|\| y0u 3><7|24c7 m0|23 hp 0|\| H0|\|d474 7h4|\| |\|0|2m4l p1ggy b4ck5? Y35, 4b50lu73ly. \^/h37h3|2 17'5 \^/0|27h 17 15 up 70 h0\^/ much y0u v4lu3 y0u|2 p|20j3c7
It all depends on what setup you are going to run
90% of the time hondata will make more power then anything else because it has to be tuned & tuned & tuned.
Guest
Posts: n/a
|\|0, 17 d035|\|7 h4v3 70 b3 7u|\|3d 4|\|d 7u|\|3d. 7h3|23 15 m0|23 70 7u|\|3 7h4|\| 4 V4FC c4|\| d0.
1 c4|\| 7u|\|3 1g|\|1710|\| 71m1|\|g 1|\| 300 |2pm 1|\|c|23m3|\|75, fu3l 3|\||21chm3|\|7, c0mp3|\|5473 f0|2 v3|2y l4|2g3 1|\|j3c70|25 (1 h4v3 m4d3 900cc 1|\|j3c70|25 1dl3 4|\|d |2u|\| l1k3 570ck 0|\| 4 |\|/4 m070|2) v73c 3|\|g4g3m3|\|7, |\|17|20u5 fu3l 3|\||21chm3|\|7, |\|17|20u5 1g|\|1710|\| |2374|2d, 4/c 5hu7 0ff, 1dl3 5p33d, d154bl3 |\|33dl355 ch3ck 3|\|g1|\|3 l1gh75, 4dd 4 5h1f7 l1gh7, 4|\|d 1 c4|\| 0p710|\|4lly 4dd d474l0gg1|\|g 4|\|d 4 7h|233 574g3 |23v l1m173|2.
7h3|23 4|23 m0|23 7h1|\|g5 70 7u|\|3 4|\|d m0|23 p0\^/3|2 c4|\| b3 h4d f|20m 17 - bu7 0|\|c3 17'5 7u|\|3d, y0u d0|\|'7 h4v3 70 3v3|\| 7h1|\|k 4b0u7 17
Originally posted by Vapor
no, it doesnt have to be tuned and tuned. There is more to tune than a VAFC can do.
I can tune ignition timing in 300 rpm increments, fuel enrichment, compensate for very large injectors (I have made 900cc injectors idle and run like stock on a n/a motor) vtec engagement, nitrous fuel enrichment, nitrous ignition retard, a/c shut off, idle speed, disable needless check engine lights, add a shift light, and I can optionally add datalogging and a three stage rev limiter.
There are more things to tune and more power can be had from it - but once it's tuned, you don't have to even think about it
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Anyways, oh well.. Hondata is great if you can afford it...
Guest
Posts: n/a
You do have the option of tuning Hondata yourself, just liek a VAFC, HOWEVER, it is MUCh more advanced then a VAFC, so you will have to learn more.
It also takes some learning to tune a VAFC, and of course, all of them should be done on a dyno.
I would not touch hondata with a 10 ft poll on a motor which I invetested tons of time & money into :-/
