V-AFC causing code 22
Old Sep 24, 2003 | 10:58 PM
91integrals/vtec's Avatar
like the above posts, check out the wiring.. if not check to see if your oil pan has dents which would also cause a code 22. ( had the same problem, not enough oil was getting into the oil pick up screen) or just change your oil and fill to the second line.. hope that helps
Old Oct 15, 2003 | 02:06 PM
Noahsblack2003's Avatar
Cbr 1000 Rider
Its your computer in the car u have a obd2 and it dont take modes to well, i have a prelude and i change my obd2 for a obd1 and everything is great now
Old Oct 16, 2003 | 12:25 PM
xatracing's Avatar
did you hook up the VTM signal? make sure that you have the vtec wires going to the correct place. its very specific that one wire goes to the harness and one wire goes to the ecu. and you have to cut the factory wire. ive seen people just add onto the vtec wire. its not a tap, its an intercept.
plus, too, check your oil level.
and make sure you spaced your grounds with the brown being closest to the ecu
