Pics from July's 26psi ownage...
Old Sep 22, 2003 | 07:00 AM
chi town brat's Avatar
! Ne shab'rud'ni !
"ang, there's f*n oil everywhere...it's like a lake"
about time i get to see the pics. dayum what a mess.
Old Sep 22, 2003 | 07:08 AM
99B16Si's Avatar
what broke exactly when u tried to run 26psi? im guesseing a rod by the oil everywhere, its probably the only thing that could puncture the block?
Old Sep 22, 2003 | 07:29 AM
MattC's Avatar
Professional Asshole
i wish i was there to see that.... it woulda have been hilarious
Semper Fi
Aim and Yahoo- Inkedupordie
Old Sep 22, 2003 | 07:33 AM
99B16Si's Avatar
Originally posted by Cronic
I believe detonation or just too much HP snapped a rod into several pieces, there is a rather large hole in the back of the block and 2 smaller holes in the front and back of the oil pan respectivly.
Im very impressed with the damage done.
Im waiting on some more tools to I can actually remove the engine from the car, and I prey my head is OK, else Im going to have to save up for more goodies.
too much pressure snapped the rod, whether it was from detonation or boost. not to wish bad upon your motor but i can almost guarantee your head is fucked too. think about it....the rod snapped, so where'd the piston go?? it either went up or down, chances are it did both, several times, while the valves were still opening and closing
Old Sep 22, 2003 | 07:50 AM
1bad-eg's Avatar
26 psi
Old Sep 22, 2003 | 11:54 AM
  #17 (permalink)
Crab Cakes's Avatar
So Lost!
Default Re: Pics from July's 26psi ownage...
As some may recall, a couple months ago I got smart, and ran 26psi on accident going over gandy... well here's some of the aftermath.
Im still waiting on an engine lift to rip the old motor out.
http://www.chaos-kitten.net/9-22-03/
Yeah, my website is slow. Blow me.
Thanks to me......
Im The Original Crab!
Old Sep 22, 2003 | 12:33 PM
  #19 (permalink)
flubyux2's Avatar
Elitist Supra Asshole :)
so wait... wasnt it originally a 22 psi spike? I thought thats what you said when you were on the phone, askin for help... and telling us that you broken down at Imperial.
IIRC, your T3 had a 7psi actuator on the internal gate right? and a 2psi drop thru that FMIC.
And you were running the Profec B right?
im just trying to think... On Kelly's car (the one that walked you at only 14 psi ), it still has the stock turbo and 9psi actuator... the Profec B on Hi boost, cranked all the way up, only allows it to get up to 22 psi, on a COLD day. On Sean's car w/ the 50 Trim, the 14psi actuator and the SAME EBC... his would hit 29 on cold weather.
So, i guess what im getting at is... if you DID happen to run 26 psi (Thanks George ) you might want to check out your actuator... that might be busted and not pulling the WG open.
Oh, and if there was a boost spike, that means that there wasnt enough fuel to support that much airflow, so its most likely the breakage was caused by detonation... not the sheer amount of HP. If the car was STILL runnin super duper mega-happy rich w/ the boost spike, then its just a matter of not having enough octane... cuz a car will still detonate regardless of how rich it is if there isnt enough octane to support the airflow.
Oh, and you probably bent at least 2 valves. the same thing happend on Kelly's car, and the piston went up to the top of the bore, got bounced back down to the bottom when it ricocheted off the intake valves (and bent them).
Oh sorry, my finger slipped, i didnt mean to insert that
