CRX B16 WIRING PROB?? help
Old Sep 22, 2003 | 05:35 AM
2qk4u's Avatar
Default CRX B16 WIRING PROB?? help
just got it off the board for 1500
89 crx si with b16 swap
i am starting to try and access what is the problem, this is what i know.
swap was done by colin about 2 yrs ago, it looks farely clean still.
whatever battery i try wont get power to start car, i can get headlights and clock ect,,, but when i turn the headlights on all the other stuff dims but the headlights work fine
you can jump the starter to the battery and the car will turn over but not start. i also checked the power and grounds for good connections and tested them to see if there was a short which there was not.
i am starting to wonder if its the main relay or someshit.
cuz right now i turn the key and get jack shit.
i looked for blown fuses and loose wires and found nothing. the harness seams to be fine, and where the ecu is looks clean also
any help is appreciated
and if ur real smart and can help fix i can pay u
Old Sep 22, 2003 | 07:37 AM
KJ's Avatar
KJ
bored at work
Try changing ou the whole fusebox.
Old Sep 22, 2003 | 09:34 AM
2qk4u's Avatar
i got a whole 91 teg for parts its the same fuse box right?
Old Sep 22, 2003 | 09:36 AM
KJ's Avatar
KJ
bored at work
yeah same box. Check the fuses though to make sure they are the same values.
Old Sep 22, 2003 | 01:33 PM
2qk4u's Avatar
fixed it
the ignition wire was not goin all the way to the starter
made a jumper off the ignition all good
Old Sep 22, 2003 | 02:08 PM
MattC's Avatar
Professional Asshole
u got it running? awsome wish i coulda
Semper Fi
Aim and Yahoo- Inkedupordie
Old Sep 22, 2003 | 02:10 PM
MattC's Avatar
so it was the ignition switch than when u hooked the starter back up it ran right?
Semper Fi
Old Sep 22, 2003 | 07:42 PM
2qk4u's Avatar
no the ignition wire was not making it all the way to the starter.
we spliced into the correct wire and ran a new wire into the harness so the starter would get power.
when u had the car the ignition switch was bad and the wire had a break in it thats why when u jumped the starter it wouldnt start cuz the ignition.
Old Sep 23, 2003 | 06:17 AM
MattC's Avatar
its always those gay little things, well have fun w/ it now that its running, like i said it was going to be ur gain and my lose
Semper Fi
