ctr pistons and eagle rods
Old Sep 12, 2003 | 05:12 PM
a.essential's Avatar
The Phunk Phenomenae
Default ctr pistons and eagle rods
will it work? i heard they don't fit. let me know.
Old Sep 12, 2003 | 07:06 PM
yeah, but that's more money. i already got the eagle rods and just want it to be easy.
Old Sep 12, 2003 | 09:04 PM
mtber's Avatar
Call eagle and ask.. simple enuff.
Old Sep 12, 2003 | 10:37 PM
LS_ken-e's Avatar
A.D.D. for life
i don't believe so...
stock honda pistons use pressed wrist pins. after market pistons use floating wrist pins. something like that.
*corrected: had it backwards*
someone correct me if i'm wrong, but i think that's correct.
LOOKING FOR 3rd Gen Integra windshield trim! HELP!!!!
not your typical honda driver...
AIM: kenracer18
Old Sep 12, 2003 | 10:42 PM
qitstrn's Avatar
Can you spot me 20 cars?
you have to press stock pistons on to the rods.
Old Sep 12, 2003 | 10:50 PM
KJ's Avatar
KJ
bored at work
stock b-series pistons are floating pin and stock rods are press fit. Eagle rods are floating pin and designed to be used with a piston that uses retainer clips to hold the wrist pin in . If you run the eagle rods with ctr pistons the wrist pin will float out and into the cylinder wall and basically destroy the whole motor given enough time. OEM pistons can be machined to use the retaining clips but it would probably get pricey and I don't know of anyone who does it locally. I heard Bush and Leitner in Canada does it.
Old Sep 13, 2003 | 06:23 AM
99B16Si's Avatar
yep, its all in the rod
