Injectors
Old Sep 1, 2003 | 08:23 AM
Josh's Avatar
Dr. Doom
Originally posted by Pappy
S2000 injectors run at 360cc, not 310cc
Nick
Old Sep 1, 2003 | 09:58 AM
RaIn.'s Avatar
I had 290cc prelude injectors on my ls/vtec setup w/ about 11.9:1 comp. and when I dynoed it showed that they were still to big, causing me to run rich as hell. I would suggest just using any other stock honda injector (240cc)
Old Sep 1, 2003 | 12:15 PM
qitstrn's Avatar
Can you spot me 20 cars?
I ran stock injectors on boost (gsr)225whp thats as much as they will take.A stock ECU can only run 370 injectorss max!!! You will damage your motor if you run anything bigger.
Old Sep 1, 2003 | 12:28 PM
98hciv's Avatar
ls/vtec turbo on the way!
thanks everyone, Im putting ls injectors in tonight Ill let you know how they work.
Old Sep 1, 2003 | 01:37 PM
  #17 (permalink)
RyanCivic2000's Avatar
Fuck the DOHC
How are you going to damage your motor if you run big injectors? If anything you just won't idle or be able to start the car.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old Sep 2, 2003 | 05:22 PM
  #19 (permalink)
redcrx187's Avatar
ALL MOTOR LS/VTEC
go with r/c 310 injectors they will be fine and wouldnt be a bad idea to get a walbro fuel pump
