wobbling steering wheel
Old Aug 29, 2003 | 01:21 PM
LsTegDude1's Avatar
I'm the green one
Default wobbling steering wheel
i dont work on cars too much i just know some book stuff like what redlines at what and what motor has this much horsepower and such but why is it that when i get on the highway or any street for that matter and go about 80mph or more the steering wheel starts to shake side to side a little bit then the faster i go the more it shakes do i need new tires or something or like alinment? this might be a simple question for some of you out there but i really dont know why if you could help me out thanks brian...
Hey chicken maybe you wanna be a french fry!
Maybe I DO!
Old Aug 29, 2003 | 01:55 PM
Sunrise City Rider's Avatar
WHAT!?! OK!......
Your wheels need balancing, the hubs are not for a Honda, the tires are not 100% round, the wheels are not 100% round...Those are your most likely choices...
My money is on the tires or tire being out of balance...
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old Aug 29, 2003 | 01:57 PM
Vtec4theChildren's Avatar
tire balance first
if that doesnt solve it then most likely hub bearings
jack the car in the air and see if the hub has in and out play
Old Aug 29, 2003 | 02:04 PM
civicracer901's Avatar
B16ACRX
due that by jacking the car up off the ground. Shake the whole wheel side to side. You will know if there bad or not by alot of play back and forth. If you can shake your tire and while doing so Check you inner tie rod in also. And also just look at your tires and spin them see if its bent (wheel) or seperated tires. Vibrations have nothing to do with alignments. That vibration usally is caused to tires out of balance or loose broken parts. Somthing like that. When you align a car all your doing is turning nuts and bolts basically.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Aug 29, 2003 | 07:18 PM
BitbyStreetRacin's Avatar
once your bit, your done.
it may be the rack...
get someone to get into the car and turn the wheel left and right and look on the rack boots, they are more than likely ripped...
at least thats what my wobbly steering wheel problem was.
worth a look
Old Aug 30, 2003 | 03:13 AM
01IntegraGSR's Avatar
...transformer...
Is your car lowered?
I have a Teg too and my steering wheel does the exact same thing almost exactly when I hit 80mph. I went and got my wheels balanced, alignment, I have new tires on it....still does it. Actually, depending on what surface road I am on it is either less or more shakey. Could just be a Honda thing b/c most of my friends have the same thing happen with their cars but worse.
Old Aug 30, 2003 | 04:30 AM
LsTegDude1's Avatar
I'm the green one
nope its not lowered its all stock i wish it would stop lol but i'll try to do what you guys say but i'm a little afraid to spend any money on these tires i have now thereshitty and i need new ones pretty soon and i wanna upgrade to some SI whees, sawblades or even some HX wheels and i would get tires for those cause these steelies suck
Maybe I DO!
Old Aug 30, 2003 | 08:39 AM
Josh's Avatar
Dr. Doom
S-U-S-P-E-N-S-I-O-N
