MSD SCI-L Installation
Originally posted by mike34655
I think I am going to put it behind the center console.
Im The Original Crab!
Guest
Posts: n/a
1'd m0u|\|7 7h47 7h1|\|g d1|23c7ly b4ck 1|\| 7h3 b0><, 4|\|d pu7 b4ck 0|\| 7h3 5h3lf, 3b4y, 0|2 7h3 g4|2b4g3 c4|\|.
U|\|l355 y0u 4|23 m4k1|\|g m0|23 7h4|\| 500\^/hp 4 c0|2|23c7ly |2u|\||\|1|\|g H0|\|d4 1g|\|1710|\| 5y573m 15 m0|23 7h4|\| 5uff1c13|\|7.
Originally posted by Vapor
I'd mount that thing directly back in the box, and put back on the shelf, Ebay, or the garbage can.
Unless you are making more than 500whp a correctly running Honda ignition system is more than sufficient.
Odds are, if you are having trouble with the spark in your car, you should fix the issues first. A set of plugs, plug wires, cap/rotor, ignitor and main relay are all key elements on the "new parts list" that every owner of an elderly Honda should address first. While some cars may need a MSD box to function correctly, most Hondas won't require it. The absolute MOST I would do is an external coil conversion if your internal coil is shot. Personally, I would even try to avoid that and use it as a last resort. Why have more clutter and wires running through your engine compartment too?
