speedometer
Old Jul 30, 2003 | 08:36 PM
Terraj92si's Avatar
Caucasion Invasion
Default speedometer
i had a little problem tonight driving home from work. the whole time i was driving the speedometer never worked. it stayed at 0 the whole time. the rpm's worked fine but not the speedometer. help me out to let me know whats wrong and what i need to do
-Terraj
Old Jul 31, 2003 | 01:30 AM
MadisFastDSM's Avatar
tractionless
speedo sending unit
collision and refinising technician need bodywork/ paint call 727 776 7830
Old Jul 31, 2003 | 07:06 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
not sure if the 92's had speedometer cables but if so that'll be the reason, it happend to mine and I was out if vtec because of it.
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
Old Aug 1, 2003 | 10:10 AM
Terraj92si's Avatar
Caucasion Invasion
ok so if its the speedometer cable, where is that located so i can check it out cuz i dont really feel like sendin it to some guy and maybe gettin ripped off
-Terraj
Old Aug 1, 2003 | 10:12 AM
Terraj92si's Avatar
Caucasion Invasion
o i forgot to mention that this happened about a month ago for like 2 minute then it shot up to the speed i was going. i dont know if that changes what it could be or not
-Terraj
Old Aug 1, 2003 | 10:26 AM
RARE1NONLYCIVIC's Avatar
I HAVE SAME PROBLEM RIGHT NOW SO WHEN U FIND OUT TELL ME B/C I DONT KNOW HOW FAST IM GOIN AND DON'T HAVE V-TECH
Old Aug 1, 2003 | 03:25 PM
Terraj92si's Avatar
Caucasion Invasion
ok i will IF ANYONE EVER HELPS ME
p.s. no h in vtec
-Terraj
Old Aug 3, 2003 | 09:26 AM
it won't fix you V-TECH , however, if your car is equiped with vtec it wil fix that. the cable runs from the back or your cluster, down through the firewall and into the tranny. this is assuming you have a speedocable, newer cars use a electrical signal. you'll need to pick up a new one from Honda for about $20
153.5 whp AllMotor
Old Aug 3, 2003 | 12:29 PM
Terraj92si's Avatar
Caucasion Invasion
ok i guess ill try to find it. the weird part is that my odometer isnt working either. also for a few days after that started, the first few days when i turned on the car it would work for a few minutes then die. i dont get whats going on.
-Terraj
