I was ready but need help, Starting problem in b16a crx si
Old Jul 29, 2003 | 04:11 PM
100whplusperliter's Avatar
Default I was ready but need help, Starting problem in b16a crx si
I got the swap all done last sunday in my 1991 crx si
it all went great except for mounting that mother that took almost a full day
But now when i tried to start the engine it will fire the cylinders wile cranking but not start. My header is not bolted to the exhaust so i can hear the engine compressing and firing.
Should i keep on cranking? What could be the problem?
Old Jul 29, 2003 | 04:15 PM
KJ's Avatar
KJ
bored at work
If the b16a motor hasn't been run in a while alot of times the injectors will be clogged/stuck. Tap them gently with a wrench or something while trying to start it. You say it is firing but do you know for sure?
Old Jul 29, 2003 | 04:20 PM
the engine fires but does not start. I might have the plug order on the cap mixed up i dont know what it is?
Old Jul 29, 2003 | 05:01 PM
j0shth3j3w's Avatar
Everything is for trade.
12
if your looking at it straight on from the tranny side facing the distributor looking thru it to the cam gears.
you --->dist[engine]cam gears
Josh
Just text me.... 813-785-5222
Old Jul 29, 2003 | 05:16 PM
It works that bitch is riding !!!!!!!!!!!!!!!!!!!!
thanks everyone
now i need to do some final tuuning
