speedodmeter question
Old Jul 29, 2003 | 03:11 PM
bart's Avatar
h22 hatch
Default speedodmeter question
IM ON MY BOYS SCREENNAME BUT I HAVE A QUESTION FOR YALL HONDA FANATICS
OK I HAVE A 94 CIVIC COUPE W/ B16A AND MY SPEEDOMETER WILL NOT WORK BUT REST OF CLUSTER WILL, ALREADY CHANGES VEHICLE SPEED SENSOR AND YES IT IS GETTING POWER BUT IT STILL WILL NOT WORK.
*** IF ANY IDEAS TO FIX IT TELL ME PLEASE***
dead once again
Old Jul 29, 2003 | 05:23 PM
JamesH's Avatar
I'm just her baby daddy
i dunno if this will be any help i dont even know if this was my problem but when my timing on my b16 was advanced too much my speedo didnt work and when i set it right, it worked. i dunno tho just a thought.
Old Jul 30, 2003 | 05:22 AM
RARE1NONLYCIVIC's Avatar
THANX FOR THE HELP ILL TRY IT OUT AND ILL TELL U WHAT I FIND OUT THANX
Old Jul 30, 2003 | 06:22 AM
MattC's Avatar
Professional Asshole
could be a lot of things, i know w/ my supra i couldn't get that speedo to work and i tried everything good luck man.
Semper Fi
Aim and Yahoo- Inkedupordie
Old Jul 30, 2003 | 07:39 AM
Nata$'s Avatar
TR Balla Donor Supreme
Have you tired using a different cluster?
Old Jul 30, 2003 | 04:35 PM
YEAH TRIED 2 CLUSTERS AND STILL NO SPEEDO
Old Jul 30, 2003 | 04:36 PM
DOES N E BODY KNOW OF A FUSE FOR VEHICLE SPEED SENSOR IF SO PLEASE TELL ?????????
Old Jul 30, 2003 | 04:43 PM
rangcrx's Avatar
engine building &best
THERE should be a Ground wire cause odb's use electric speedsensors It is eather a bleck/orang or a black green wire that is under your dash easy to see make sure it is clean and tight to chassi best way to check if its getting power use volt tester and stick it in the pin for ss and go over 15miles PEr and see what you get
i love AUTOZONE
Old Jul 31, 2003 | 07:09 AM
ComatoseSedan's Avatar
Fo Shizzle My Nizzle
turn off those GOD DAMN CAPS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'88 Civic Sedan - Cardinal Metalic Red
153.5 whp AllMotor
www.LHTperformance.net
Old Jul 31, 2003 | 10:16 AM
95gsr's Avatar
AlKiF4i
AIM- Type95gsr
