LS in CRX ??
Old Jul 26, 2003 | 10:27 PM
rangcrx's Avatar
engine building &best
Default looking
guess the hasport and guess the 91 integra mount
Old Jul 27, 2003 | 04:29 AM
MattC's Avatar
Professional Asshole
u need a mount kit, or if u are skilled enough to make ur own go for it. i say get a b16 head, do an LS v-tec and than get a v-tec ecu (which one i'm not quite sure i never looked into LS v-tec's prolly would be good to get a GSR ecu... not positive). that's just my .02 though.
Semper Fi
Aim and Yahoo- Inkedupordie
Old Jul 27, 2003 | 06:03 AM
specie's Avatar
Originally posted by rangcrx
sad to say but YES 90-91 Ls 1.8 nonVtec motor mounts DRIVERS,TOPTRANNY mount WIll work in any 88-91 crx/civic swap with cable tranny,ANd then use the rear Lbracket from a 90-93 integra and Just move your STOCK crossmemebermount over to the next set of bolts:o)as for ecu use any 88.89.90.91 integra AND if you can for better PROFERMANCE use the INTEGRA map sensor
If you think that you can use the stock mounts, why do you think there are so many companies making B-series swap mounts into 4th gen Civics? Why don't you prove this? As well as installing a Skunk2 Intake Manifold in 10 minutes? The rear mount bracket from the '90-93 Integra is the same as the '88-91 Si. If you don't know, don't spread misinformation.
The ecu is a PR4 (non-OBD).
Old Jul 27, 2003 | 08:16 AM
rangcrx's Avatar
man i guess you cant read eather SPECIE but its ok your a kid ANd anytime you would like i will let you see STOCK MOUNTS HOLDING IN A PERFECT VTEC SWAP INTO A CRX's you are a just one sad loser dont try and be some keyboard hardAss ok thanks and please reread what i wrote I SAID FOR THE REAR tranny mount all yo uhave to do is move yours OVER stupid,ANd to prove me wrong how did the japanise get this vtec engine into there CRx's sir wow thay must have went into the future and bought kits from hasport AND IT WAS A JOKE ABOUT SEEING THE HASPORT MOUNT AND THE STOCK INTEGRA god you people cant read
i love AUTOZONE
Old Jul 27, 2003 | 08:32 AM
rangcrx's Avatar
OK HOW ABOUT THIS IF EEATHER ONE OF YOU MASTERS ARE SO SURE THAY WILL NOT WORK PUT SOME MONEY DOWN ON IT HOW 50BUCKS? i mean you guys both sounds like pro's let me no ok be real men and take this beat i will give you 4/1 odds
i love AUTOZONE
Old Jul 27, 2003 | 08:40 AM
  #17 (permalink)
KJ's Avatar
KJ
bored at work
I've used the stock mounts before but it requires removing and re-welding the passenger side framerail bracket. I'm 100% sure of this and will take you up on your $50 bet. The motor does not simply bolt in, it does weld-in though.
The JDM sir had the passenger side framerail bracket welded in the correct place from the factory, they also had a different front crossmember.
Honda usually leaves the framerail brackets in the same place for all models, this is why the 94+ integra motors bolt into the 92+ civics so well. They did not do this in 88-91 though. Even in 92-95 the auto framerail bracket is not in the same place as the manual.
Old Jul 27, 2003 | 08:44 AM
  #18 (permalink)
rangcrx's Avatar
sounds good to me Kj where are you for the top tranny bracket you just need to widen it with large screw driver let me no if you want to see one and met up for this bet
i love AUTOZONE
Old Jul 27, 2003 | 10:56 AM
  #20 (permalink)
rangcrx's Avatar
BUT HE SAID it does work with a lil help mean how old are you kids that need to go back and learn to read
i love AUTOZONE
