crx integra rear disc
Old Jul 26, 2003 | 05:33 AM
kender's Avatar
gadget man
Default crx integra rear disc
will the rear disc for an 88 integra fit an 88 crx si? I know the 94 del sol bolts right in is the teg the same?
U.S.S.A Crew Member #001
Old Jul 26, 2003 | 09:00 AM
Sunrise City Rider's Avatar
WHAT!?! OK!......
Yes, use the same swap procedure as you would a 90-93 teg
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old Jul 26, 2003 | 06:55 PM
kender's Avatar
gadget man
whats the swap procedure, do I just unbolt the arms from the body and modify the e-brake to attach to the lever, which cable would be best.
Old Jul 27, 2003 | 07:39 AM
Hella Slow's Avatar
its CRACK bitch!
NO it won't work!!!!!!!!you need 90 and up teg or del sol or 90-91 cr-x si...........with thoes you need NO fabrication just bolt it in..........
_Jason
Old Jul 27, 2003 | 07:44 AM
Hella Slow's Avatar
its CRACK bitch!
I have a friend that is selling a rear disk conv. it has everything even polly bushings.....
his name is ken 727-423-6396 leave a message and tell him jason told you about it......
_Jason
Old Jul 27, 2003 | 08:31 AM
KJ's Avatar
KJ
bored at work
For a crx you can use the following rear trailing arm/brake setups for rear disc swaps.
90-91 crx si
92-95 civic si
90+ integra (any year/model, abs or non abs it doesn't matter)
For the e-brake cables you need 90-91 crx si. The teg ones and civic ones are too long and would require some creative routing if you did decide to try them.
Old Jul 27, 2003 | 08:32 AM
KJ's Avatar
KJ
bored at work
Since it is an 88 you may need the lca too, but I'm not 100%.
Old Jul 27, 2003 | 07:04 PM
Hella Slow's Avatar
its CRACK bitch!
the e-brake cables work even thoe they are 2 long use zip ties 2 hold them up ..... i've had the swap for 4 1/2 years on my 90 si hatch and it came from a 91 teg. including the e-brake cables....
Old Jul 27, 2003 | 07:48 PM
KJ's Avatar
KJ
bored at work
yeah for the hatch it works. For the crx they are a little too long. It could still work but the crx si ones will fit alot better.
Old Jul 27, 2003 | 07:52 PM
WHAT!?! OK!......
Why can't you use the 88 Integra Rear Disc Brakes?
Zee
04 Civic Si
01 Lexus GS300
