turbo fuel management
Old Jul 20, 2003 | 08:20 PM
F4A22's Avatar
Old School
Default turbo fuel management
I was wondering if anybody knows which is better for fuel management for my setup.I'm going to run 7lbs on a t25.I have a v-afc and some 450cc dsm injectors. since i'm runnin such low boost if a vortech fmu is better or stick with my current setup.thanx
Old Jul 20, 2003 | 08:38 PM
Miles's Avatar
It's a wooden pickle.
hondata. end of discussion. now. call secret services. seriously, now.
Old Jul 20, 2003 | 08:52 PM
mtber's Avatar
lol hondata if your rich
look into the poormans hondata
450 injectors & an s/v afc
i personally would go for a vortech fully adjustable fmu if you are only running 7 psi.
Old Jul 20, 2003 | 09:11 PM
mtber's Avatar
You probably should ask a question like this in the forced induction forum.
Old Jul 20, 2003 | 09:27 PM
Miles's Avatar
hondatahondatahondatahondatahondatahondatahondatah ondatahondatahondatahondatahondatahondatahondataho ndatahondatahondatahondatahondatahondatahondatahon datahondatahondatahondatahondatahondatahondatahond atahondatahondatahondatahondatahondatahondatahonda tahondatahondatahondatahondatahondatahondatahondat ahondatahondatahondatahondatahondatahondatahondata hondatahondatahondatahondatahondatahondatahondatah ondatahondatahondatahondatahondatahondatahondataho ndatahondatahondatahondatahondatahondatahondatahon datahondatahondatahondatahondatahondatahondatahond atahondatahondatahondatahondatahondatahondatahonda tahondatahondatahondatahondatahondatahondatahondat ahondatahondatahondatahondatahondatahondatahondata hondatahondatahondatahondatahondatahondatahondatah ondatahondatahondatahondatahondatahondatahondataho ndatahondatahondatahondatahondatahondatahondata
if you sit down and think about it, the hondata is only going to cost you like 1-200 more, and do SO much more than any vafc will ever do. did you plan on getting that thing dyno tuned with the vafc? because you're going to have to... if you're going to go turbo, do it right, don't blow your shit up because you skimped a hundred bucks on the engine management. look at www.hondata.com if you don't believe me. call john at secret services. explain what you plan on running, and he will tell you the same thing. hondata is the only way to go.
