Am I ready b16a swap CRX
I plan on doing a b16a swap next weekend in my 91 CRX si can someone give me some pointers of anything I might mess up or forget ? This is what i have Thanks
b16a with y1 lsd
ecu pow
radiator hoses
mounts hasport
shift linkage
i made a sub harness 4 wire
raxles
throttle cable
oil filters 2
fuel filter
ngk plugs
fluids
tools
8mm punch
dental picks
b16a with y1 lsd
ecu pow
radiator hoses
mounts hasport
shift linkage
raxles
throttle cable
oil filters 2
fuel filter
ngk plugs
fluids
tools
8mm punch
dental picks
Add to that a h2o pump, thermostat/gasket, new timing belt and a cap/rotor. Once it is running you can determine if it needs other things. Pretty much, you can count on a new ignitor if the tach jumps and some new o2 sensors for good measure. Check the motor over very carefully for broken sensors and whatnot on the back side. Now would be a VERY good time to do an intake manifold swap as they are a royal PITA once the motor is in the car. I know from first hand experiance.
check the cam seal too after you get it in running, i know both my b16's had bad cam seals and leaked some oil.
and i have a pr3 ecu that would be a perfect canidate to chip if youre interested at all
you may want to bend the little sectionof the rear cross member down. the rear tranny mount will hit it and make your car viberate like hell. i had to pull my engine out twice to figure it out.
tamparacing.com
32 mm for the axles change your brake pads more power needs new brakes while your doing all this be careful of the tps sensor not to stretch the wires while your pulling the old motor and installing the new one. good advice on checking the sensors completely hook up your harness while the motor is out so all you have to do is the top connections. str makes a good cam seal. if the motor has not been rebuilt or anything all you should have to do is change it once its in and run it. good luck have fun and take your time if you get frustrated walk away and take a break dont rush it. where are you located at get someones number that is close to you in case you need some last minute help.
Josh
Josh
