Guns & Ammo Guns, Ammo, Knives, Weapons.. etc..
Solution for fire ant bites....first aid tip When fire ants bite you, they bend over
Old Jan 14, 2021 | 07:57 AM
Default Solution for fire ant bites....first aid tip When fire ants bite you, they bend over
Solution for fire ant bites....first aid tip if you are in the woods...
When fire ants bite you, they bend over and spit digestive juices into the wound.
It forms a "pimple" that forms a lump/welt, gets infected and takes forever to heal.....if it ever does.
When they bit me working in the yard, I scraped away the pimple first. It bled a bit.
I then sprayed the wound with brake clean. It disinfected the wound and brake clean
always dries your skin.
Burned for a bit....briefly. Kept wiping off the blood until it dried over.
It now has a thin scab over it and the healing process has begun.
I may be applying Neosporin or an aloe plant next... to speed up the healing
Had I done nothing, the ant bite would still be there.
Passing it on.
Jan 14, 2021 07:55 AM
Mar 14, 2017 04:55 AM
Feb 8, 2013 08:35 PM
CBER
Dec 11, 2005 07:06 AM
