Numbers Game: Buckshot For Home Defense Bob Campbell
Bob Campbell - 10/14/2020
The shotgun is regarded as the “ultimate problem-solver” when it comes to personal and home defense. There is no denying its wound potential or hit potential. However, the shotgun is underutilized because many shooters do not take the time to master the piece.The shotgun has a great measure of finality against felons and dangerous animals at close range and is a formidable and versatile firearm. However, do not be in the situation of being armed with a deadly weapon you are not able to use well. The good news is that quality shotguns need not be expensive.
While I own fine examples of 1911s, a SIG P210 and a Colt Python, I am not so particular when it comes to shotguns. I own a long-serving Iver Johnson single-shot and a couple of well-worn Remington 870 pump-actions. They are reliable, rugged, easy to use and effective. Were I to find myself in a deadly situation, my Beretta tactical self-loader would be my choice. But a homeowner on a budget may be better armed with a hundred-dollar shotgun than a thousand-dollar handgun.
Where the shotgun gets complicated is in load selections. Lightweight birdshot may (and should) be used for practice, but it is ill-considered to recommend it for personal defense. Birdshot doesn’t offer sufficient mass and penetration. On average, birdshot loads penetrate 3 to 6 inches of gelatin, which is hardly adequate. Heavy clothing may also absorb the majority of birdshot’s energy. I won’t waste any more time on this inferior loading save to repeat that birdshot is designed to humanely down a small fowl weighing but a few ounces.
The shotgun — so called because it launches a number of lead balls called “shot” — sends those lead balls in a group called a “pattern,” but the resultant pattern is often misunderstood. The shot travels in strings, and the dispersion is greater at distance. At close range, such as those typical in home-defense contexts, the shotgun must be aimed as carefully as a rifle, and the only real choice is between the larger sizes of buckshot — namely 00, No. 1 and No. 4.
COMPARING THE LEGENDS On the left is a round of 230-grain .45 ACP, included for scale. To its right is a pellet of No. 4 buckshot (about .24 caliber), and next to that is a pellet of 00 buckshot (about .33 caliber). On the right is a 12-gauge “Foster” slug, which works out to about a .72-caliber hollow-based bullet. Most 2.75-inch 12-gauge shells will contain either 27 pellets of No. 4, nine pellets of 00 or a single slug, and they will all be loaded over a larger powder charge than you would find in a “field load” designed for shooting trap or skeet.Pattern of Behavior
It is important and very much neglected to pattern the home-defense shotgun, and the home defender must understand that pattern. Put simply, the pattern is the width and length of the buckshot load on paper. That is the first step in assessing a pattern (but hardly the last). Do the pellets strike high, low or to one side? As with all firearms, different loads will perform differently in a specific gun.Also remember that, at normal personal-defense ranges, you can still easily miss your target with a load of buckshot. At longer ranges — 12 to 15 yards — the spread of the pattern makes the shotgun more attractive in addressing moving targets or partially exposed targets. But at close range, don’t kid yourself: People can and do miss attackers with shotgun fire.
Shells loaded with 00 buckshot can contain anywhere from eight to 18 pellets, but most commonly hold nine; No. 1 buckshot, 16; and No.4 buckshot, 27. Three-inch magnum loads may contain more, but their increased recoil generally makes them ill-suited for self-defense. The smaller buckshot balls are less likely to penetrate excessively and more likely to flatten on walls and supporting structures, and they also do not travel as far as the larger balls.
As with handgun ammunition, it is important that shotshells be reliable and feed properly in your firearm. You may be surprised by how much can go wrong as a shell travels from the tube magazine to the chamber. Crimps can come apart during the feed cycle and, as with semi-automatic handguns, some firearms just plain don’t like certain brands and styles of ammunition. Whatever load you select for self-defense and home defense, be certain you have tested it for reliability as well as accuracy.
When testing the following loads, I used a standard silhouette-style target and fired at 7, 10 and 15 yards. I evaluated and averaged the performances. (Note: The Winchester PDX Defender uses only three buckshot balls loaded over a 500-grain slug.)
At 7 yards, there isn’t much real difference in the context of home defense. Twenty-one feet is a long hallway in most homes. If your shotgun is to be used for any kind of outdoor self-defense, then patterning at longer ranges is relevant. But as you perform your own tests, stick to distances most likely encountered in your residence.
No. 1 buckshot offers consistent penetration, good patterning and less recoil than 00 buckshot, though 00 is the more proven in wound ballistics. As Hornady implies in the name of its No. 4 buckshot — Varmint Express — that size is a good choice for fast-moving and small wild animals, such as coyotes. Any of the three loads is effective at moderate range. As for penetration in gelatin, No. 4 averages 10 to 13 inches, No. 1 buckshot averages 12 to 14 inches, and No. 00 averages 18 to 20 inches.
When these loads are tested, the No. 4 and No. 1 buckshot loads seem attractive for home defense. Penetration is adequate, and they are less offensive as far as recoil goes.
A word of caution, however: If the offender is heavily garbed or if the shotgun may be used for defense against big cats, 00 buckshot may be the better choice. Notably, reduced-recoil 12-gauge 00 buckshot will exhibit excellent patterns, and the loads generate penetration and wound ballistics similar to full-power 00 buckshot. This eliminates concerns with over-penetration, as the shot will stay in the body, though your greatest defense against over-penetration is to center your shot on the attacker.
Buckshot Load Pattern TestingA Pennyweight of Lead
I would be remiss were I not to address slugs — traditionally lumps of soft lead with rounded noses, though they can be found in hunting iterations made from solid copper with hollow points. If we’re just going by the numbers, there is no shoulder-fired weapon that equals a shotgun loaded with a slug when it comes to wound potential at close range. Most slug loads launch a 500-grain solid projectile at 1,400 feet per second; for comparison, a classic .45-cal 1911 sends a 230-grain bullet at just under 850 feet per second. A 12-gauge shotgun slug is, in short, devastating.Even with all of that power, the slug isn’t as offensive in penetration as you might think. Most exhibit 12 to 14 inches in gelatin, and some throw off a shard of lead in the wound path. The Remington slug, as an example, begins at 0.72 inches wide and expands reliably to 1.2 inches. While reduced-recoil slugs are an option, they exhibit inferior wound ballistics, which isn’t the case with reduced-recoil buckshot. The reduced-recoil slug is accurate and easy to use but penetrates up to 20 inches in gelatin, as it does not deform or expand at lower velocities.
Pick Your Popper
The shotgun’s natural handling makes it ideal for home defense. As long as you consider the likely targets and environments for its use and select the proper load, it’s a tough option with which to go wrong. But as in everything else in the world of self-defense firearms, you need to do your homework. After deciding on which size of pellet you intend to use for defense, it is your responsibility to figure out which brand and load patterns the best out of your gun and then run through a box to check for reliability. Once that’s done, you can switch back to the trap loads for training, but don’t shortchange your personal-protection plan.Sources
Colt: Colt.comHornady: Hornady.com
Remington: Remington.com
SIG Sauer: SIGSauer.com
Don’t Go There! Avoiding Trouble Hotspots
Kevin Michalowski - 08/26/2020
You’ve got your gun. You’ve got your permit (if you live in a state that requires one). You’ve even gotten some training. So now you are ready to go anywhere, right?Wrong.
Stay Away From Trouble Hotspots
Remember the rule: If you would not go into an area without your gun, don’t go there with your gun.The gun is not some magic talisman that protects you from danger. What the gun does is give you an advantage. It helps even the odds. It allows you to respond to danger with equal danger.
But what if, for whatever reason, you rounded a corner and found yourself headed right into a mob? Think about how quickly things could go from “peaceful protests” to uncontrolled mob violence. Are you prepared?
Don’t just slap your hip and say, “I got my gun.” If that is the way you think, you will likely die.
Stay on Top of Things
Being prepared means being informed. Know the gun laws in your state. Watch, listen to or read the news and think about how it might impact your community. Situational awareness dictates that you have that information. Conflict avoidance demands that you act on it. You can only avoid the trouble spots if you know where they are.At the same time, you need to consider your worst-case scenario. What are you going to do when you come around that corner and you are facing a riot? What are you going to do if you are sitting in your office and you look out the window and the streets are on fire? The only things available to defend yourself are the things you can reach right now. Look around you. How screwed are you?
Property Isn’t Worth Dying Over
It is imperative to understand that as much as you cherish your property, it is not worth more than your life. As I said in the past, self-defense is not “stuff” defense. Don’t take a life or lose your life over some inanimate object. It can be replaced. Courts have ruled that any use of force must be “objectively reasonable.” This applies to your vehicle — unless, of course, you are facing imminent, unavoidable threat of death or great bodily harm and can’t flee.What if the trouble comes to you? When it comes to your home, if you have the opportunity to retreat and safely escape, do so. If you’re facing an immediate deadly threat, that is one thing. But it is another thing if protestors are marching by your property and you point your gun at them. Firearm Rule No. 1: Don’t ever point your firearm at something you don’t intend to shoot. Besides, doing so can get you in a boatload of legal trouble.
My ‘Get-Home’ Kit
If you live in or commute through an urban area, now might be the time to assemble an emergency kit. I’m not talking about three Band-Aids and some tape. I’m talking about having ready access to the tools that will keep you alive in a crisis. You will need a gun, ammunition, a flashlight, batteries, a good multi-tool, an individual first-aid kit, maybe more. And then you need to have it with you.I recently reviewed and organized the contents of my bug-out bag. It’s a serious backpack with enough gear to keep my kids and me safe and warm for three days in the event of a natural disaster or other crisis that would leave us displaced. As I looked at the contents and considered adding some more items, I thought, “Nice kit, but what good will it do if it is not with me when the worst happens?”
So I immediately started creating a “get-home” kit that will help me get back to my bug-out bag. It’s a smaller kit with a gun and some ammo, some OC spray as an alternate weapon, a spare key for my house, and a few other items I figured I might need.
I guess that means I have my concealed pistol on my person so I can fight my way to my get-home bag and then decide whether or not I need to use my bug-out bag to get out of Dodge.
Have a Plan
My first priority is to be on the lookout for trouble and avoid it. Second is staying informed (which will likely allow me to avoid trouble in the first place) and preparing for it. If I see crazy coming, I cross the street. I won’t go there. If trouble comes to me, I have a plan in place.
Florida: House Passes Constitutional Carry
view the web version of this email
Today, the House voted 76-32 to pass House Bill 543, the constitutional carry bill. It will now go to the Senate for further consideration. Please contact your state senator and ask them to SUPPORT HB 543.
House Bill 543, constitutional carry, strengthens the right to self-defense in Florida by recognizing the right of any law-abiding adult who is at least 21-years-old and legally eligible to obtain a carry permit, to carry a handgun without first having to obtain government permission. This ensures that citizens have their right to self-defense without red tape, delays, or fees. It does not change who is eligible to obtain a carry permit. It also does not affect previously issued permits, and allows citizens who still wish to obtain a permit in order to carry in other states recognizing Florida’s permits, to do so.
Your NRA would like to thank lead sponsor Representative Chuck Brannan for bringing this important legislation and Speaker Paul Renner for his exceptional leadership through the process.
Again, please contact your state senator and ask them to SUPPORT HB 543.
FOLLOW NRA-ILA
FOLLOW NRA-ILA
Guns & Ammo
Aug 6, 2019 07:29 PM
Guns & Ammo
Mar 24, 2019 04:47 PM
