Green Motoring Discussions on Hybrids, getting more MPG, alternative fuels, oil prices, electric vehicles, global warming and anything else Green Motoring related.
EV charger\welder homemade
Old Apr 25, 2013 | 02:10 PM
kegaration's Avatar
truck was sold, I might build a boat.
Old Apr 25, 2013 | 02:40 PM
kegaration's Avatar
ok some information for people to gawk at and for me to record my findings. im using 2 denso 56027913ab alternators there were about 6 of them at the yard if you get the plain 56027913 ones they have lug terminals instead of a plug.so I wired the outputs in parallel and the fields in parallel it produced 170+ volts dc. so I put the fields in series and the max power of the pwm excited the output to 130+ volts dc both at max rpm of the engine. the engine spins at around 3600 rpm and has a 6 inch shiv the altrnatrs have a 2 inch. if spun while energized there is some type of flux synchronization loop (made that up myself lol) or some thing I have no idea what its called but it seems to feedback into itself and create heat so I found at 80 volts and max engine rpm the temps stabilized at 160 *F so far I am very happy with the output and adjustability using the pwm to control the field. also it takes 4 times longer to dissipate magnetism from the field when using 2 alternators instead of one.
Old Apr 25, 2013 | 02:45 PM
kegaration's Avatar
[ATTACH=CONFIG]198014[/ATTACH]
Old May 13, 2013 | 10:14 AM
kegaration's Avatar
So far so good
After a full tank of fuel for a full throttle test run on every setting powering things and not it survived so I took it apart for paint and re assembled it. Will show video runs shortly
Old Jun 3, 2013 | 05:08 AM
kegaration's Avatar
runs awesome great power adjustability
Old Jun 3, 2013 | 07:27 AM
Loren's Avatar
I'm impressed with the creative and cheap solutions you're finding to the "EV equation". Great stuff!
Old Oct 21, 2013 | 01:18 AM
  #17 (permalink)
snarose's Avatar
Thank you sir awesome posts....
Old May 25, 2014 | 05:29 AM
  #18 (permalink)
kegaration's Avatar
still running strong
this thing Is a powerhouse.
Old May 25, 2014 | 11:54 AM
  #19 (permalink)
Thanks for the update.-Bob
DubDaze
Mar 5, 2009 07:55 PM
shinmei2006
Jan 23, 2008 08:33 PM
bori bori
Oct 26, 2006 06:08 PM
Punkinterviews
For Sale/WTB Honda & Acura
13
Sep 20, 2005 01:31 PM
superdave
Apr 15, 2004 06:34 AM
