noise after swapping ring and pinion
Old Oct 15, 2002 | 10:09 PM
87IROC_Z's Avatar
Default noise after swapping ring and pinion
well after my mishap last week at the track,I decided to put a new ring and pinion in the IROC. I got it in it drives well but i am getting a noise like the sound that you would get if your front wheel bearings were on they're way out. any ideas?BTW for all of you that didn't make it out to sunshine speedway last wed,I was the black iroc clanging down the track.Hell of a launch though
Nothing Special,87 IROC Z, 355 tpi,catco hi-flow cat 3 inch exhaust,shift kit,vette servo,K&N,gutted airboxes,X-rod/ARP bolts....blah,blah,blah
Old Oct 15, 2002 | 10:23 PM
Uncle Ben's Avatar
Rice Cooker
Did you do this your self or have someone else do it? Gear setup requires that tolerances be precise or you will have noise or a trashed gear set. If these are Richmond gears and the whine is not very loud this is fairly normal for richmonds. If you are not sure that they are setup correctly try Allens Gear Works.
Uncle Ben
Slow domestic N/A automatic RWD w/LOTEC
Old Oct 15, 2002 | 10:28 PM
87IROC_Z's Avatar
A friend of mine At glennz performance put the ring and pinion in for me and i did the rest,I got the ring and pinion from allens gear works
Old Oct 18, 2002 | 11:23 AM
BigBird's Avatar
Like was said above Richmond gears tend to whine a little. If it isn't a whine your hearing and it's more like a grinding sound you might have a problem. Did you replace the crush sleeve? If you did, you might have to take it back to your friend and make sure it's still tight. Sometimes they don't crush all the way and need to be checked. If that's ok you could have a bad pinion bearing. There are a number of things it could be.
Bruce
