what is this fuse ??? spring coil ???
Old Oct 12, 2010 | 07:35 PM
mikiemike75's Avatar
mikiemike75
Default what is this fuse ??? spring coil ???
ive got an 05 grandprix gtp comp g... well my heads up display unit stoped working today it wont allow me to adjust it up and down on the window... well i did the normal checked all the fuses, wires no issues... tapped the dash and it started working... not concerned about that but i was looking through the fuse panel inside the car and seen a fuse in there its a 2amp fuse and its labeled as spring coil 2 ??? any ideas on what this may be just curious... its not poped but never heard of anything like this... did a lil google research and come up with anything other then diagrams of the fuse box... thanks in advanced to anyone who can help or has an idea...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Oct 13, 2010 | 09:20 AM
mikiemike75
bumpity...
hp~5!! trq-4!!
doing work!!!!!!
Old Oct 13, 2010 | 02:21 PM
fuelie327's Avatar
do the struts have any wires going to them ?
Old Oct 13, 2010 | 04:23 PM
mikiemike75
not that i can see... i was thinking mabey something to do with the stability control but i didnt see anything and it being only a 2amp fuse is weird... almost like a ground fuse instead of power...
hp~5!! trq-4!!
doing work!!!!!!
Old Oct 16, 2010 | 08:16 PM
03GSXR750's Avatar
Project Pat
maybe like a ground loom spliter?
Old Sep 4, 2022 | 01:16 PM
Mike5631's Avatar
its for the steering wheel switches
Old Sep 4, 2022 | 03:42 PM
Thanks for answering that......would have never thought of it.
Old Sep 4, 2022 | 05:39 PM
Mike5631's Avatar
no problem! I have an issue of my own. The radio on my 05 Grand Prix GXP. quits for no reason I have checked the fuses. All ok,have power to the radio if I totally disconnect the battery for a day or 2 it'll work until I shut off the car and nothing....very Frustrating!
