need a rearend!
Old Aug 26, 2010 | 02:33 PM
HeavyChevy3800's Avatar
405hp=SLOW
Here's something that I googled for you.
Lockers, Limited Slips and other Differentials Explained
A full spool is a type of differential. It will lock both axles together for maximum traction. Handling and turning radius will be hampered but if you want to track the car a full spool is cheap and gets the job done.
Old Aug 26, 2010 | 05:08 PM
Chronik Fab's Avatar
lol thanks for googeling that for me. isnt that equivelent to welding it though
Old Aug 26, 2010 | 05:46 PM
thumpincrazy's Avatar
wat u need i have rearend from 3500 gmc van 8 lug 14 bolt for sale
Old Aug 26, 2010 | 09:23 PM
bisscrac's Avatar
you drunk ?
here is a spool. both ends of your axles slide in the ends of this. then the ring gear bolts to the out side. its a solid rear end.
私の狂気にそこに方法があります
https://www.facebook.com/groups/534257953308376/
Old Aug 26, 2010 | 09:31 PM
bisscrac's Avatar
here it is in the rear end
私の狂気にそこに方法があります
Old Aug 26, 2010 | 09:54 PM
405hp=SLOW
It is. But when you weld it you can still break the differential or welds from shock and destroy the rear end. It all depends on what you want do as far getting a spool, locker or posi.
Old Aug 27, 2010 | 06:29 AM
  #17 (permalink)
J@meson's Avatar
Resident Ginger Kid...
If your drag racing with minimal street a spool is what u need.... go to TurboBuick.Com and u will find more info on what to do with the rear.
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Aug 27, 2010 | 08:37 AM
  #18 (permalink)
i want to be able to run the streets too. i could weld this diff or make a lock, but how streatable would that really be
Old Aug 27, 2010 | 11:57 AM
  #19 (permalink)
fuelie327's Avatar
how much money do have? Thats the key. A spool is a lot cheaper than a locker , but a locker is more street friendly. Any reputable tranny shop can install a trans brake
Old Aug 27, 2010 | 12:24 PM
  #20 (permalink)
scott hutch's Avatar
If you want to track the car and want to run the streets with it do not weld it lol just get the spool or the locker. its not worth screwing up your diff in the long run
