383 96 s-10
The stock trans will bolt up if it were a 4.3, but still that trans isnt made for the new amount of TQ. Fuel is easy, run a mechanical pump on the engine (If you going Carb'd) And you can run a fuel cell. Or run what system you have with a restrictor. Everything can be found of summit.
T56, also hit me up if you need anything for the swap. I bought the full swap and never got around to doing it before I sold my Bravada. I still have 90% of all the parts needed for an S10 v8 conversion.
sig under construction
