hid help
Old Jun 7, 2010 | 02:48 PM
matraca112's Avatar
Default hid help
i have been working on a 09 g8 with a set of hids on it and the car keeps going there ballets like water. if anyone else is going there this let me know and if someone can help me get this dam car done right. i would greatly like the help.
[SIGPIC][SIGPIC][SIGPIC][SIGPIC]
Old Jun 7, 2010 | 06:09 PM
steveyjr1982's Avatar
Blow me
Im going to assume your saying that the car is going through ballasts like water?
Do you have the harness for them that ties directly to your battery? Are these aftermarket or stock hid's?
Just a bad power steering pump:
Old Jun 7, 2010 | 06:33 PM
Whit3Angel's Avatar
Yeah I gave up after the first line.
Old Jun 7, 2010 | 07:11 PM
mikiemike75's Avatar
mikiemike75
is it going through ballast or bulbs??? bulbs could be because of chemicals on your hands when being installed or could be because of a bad seal... ballast could be because of wrongful hook up or moisture... i had to clear coat my box with electrical spray because my fog ballast kept blowing because of moisture...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Jun 7, 2010 | 09:38 PM
matraca112's Avatar
It does have a relay harness on the lights. And I know it is the ballast because as soon as I put a new one in the lights work fine. But that only last a few weeks. I have tried to even have the lights with no harness and it blows ballast even fast then.
Old Jun 8, 2010 | 08:17 PM
Blow me
Where exactly are you putting the ballasts, or better yet what kind of crap ballasts are you buying?
Old Jun 8, 2010 | 09:56 PM
matraca112's Avatar
I got a set of slim ones and they are set inside the fender well in what feels like a box in frame. I am taking it that i have to go and get better ballast but from where is the thing? Not going to rag on anyone that is selling hids here on tr but they just have the same ballast that I have been using
Old Jun 9, 2010 | 03:16 AM
Sneakin Deacon's Avatar
PSSHHH x2
you are just sitting them in there? you arent mounting them securely?
if thats the case, I think vibration would be a contributing factor if not the entirely causitive one.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Jun 9, 2010 | 09:14 AM
matraca112's Avatar
they are in there with 3m tape and they have not moved unless i have moved them. and i know because i put them in with the corners of the ballast with the frame part.
Old Jun 9, 2010 | 04:58 PM
Blow me
You should try ddmtuning.com kits, they are pretty damn cheap and high quality. Mine have yet to even flicker or flinch both my kits for that matter.
