camaro with 305 need more power
Old Jan 31, 2010 | 09:53 AM
obituary's Avatar
TR OG
yah 305 motors are garbage ...id say save 3 to 5k and buy a crate engine
1972 nova ss
89 240 sr20det
2002 chevy 1500 truck
Old Feb 2, 2010 | 05:24 PM
J@meson's Avatar
Resident Ginger Kid...
Originally Posted by jdmtegra
i alredy have the manifold and carb i know how to install the car alredy has headers and full exhaust so will it atleast make a slight difference i dont have money for an lt1 or ls1 but i do have time to put the carb on
again, its not that easy... You will need a Vaccum advance distributor, the correct linkage for kickdown, Im not sure if your cam is capable of operating a mechanical fuel pump or if you block is casted closed for the fuel pump. So there is that possibilty of running a Holley red pump to feed the carb, but then you have to tune the carb.
Does it still sound like a simple swap? Drivabilty the TBI is going to win hands down compared to a carb's tempramental attitude. A TBI setup also makes more torque then a carb will. So its a win/lose compramise, If you want more power out of your 305 cheap, sell your intake and carb and buy a set of 58cc vortec heads, aftermarket intake for the TBI with the vortec pattern, and a small cam. That with your headers and exhaust will get that car knocking into the 14's, maybe 13's if you have a posi and nice rear ratio..
And one day when time and money permits im going to build a 305, there not as bad as you think but it just takes money. I cant find it right now bc im at work but on my desktop at home I have a page of a guy who build a Camaro with the 305 and is running low 12's and I dont think its on spray yet.
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Feb 2, 2010 | 08:15 PM
Z28ricer's Avatar
Doesnt see what you did
Like I said, save your money for LT1 or LS1 swap, all this crate motor crap, and carb bullshit, is going to end up shitty.
Oh and if you are determined to build a small cube motor, L99 crank in LT1 block for a 302, or LR4 crank in L92 block for a 5.5L monster.
Old Feb 2, 2010 | 09:41 PM
steveyjr1982's Avatar
Blow me
You can get some decent power from a 305, only problem is 350's are all over the place and a direct bolt in.
Just a bad power steering pump:
Old Feb 3, 2010 | 03:01 AM
ZDriver96's Avatar
Depends what you mean by power.. I've seen the 305 get 300rwhp to the ground NA... which is stout and almost equal to the cubes... But I look at it from a 350's stand point of getting 50-75rwhp NA over your cubes (depending on which 350 etc) and having a lot more torque... and like you said easier to find...
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Feb 3, 2010 | 07:10 AM
obituary's Avatar
TR OG
this might help Third Gen Technical Articles - ThirdGen.org
Swapping from EFI to a Carb in Camaro or Firebird - ThirdGen.org
1972 nova ss
89 240 sr20det
Old Feb 3, 2010 | 11:53 AM
  #17 (permalink)
J@meson's Avatar
found it...
Welcome to Walter RaceCraft
2003 Honda 954RR
Old Feb 3, 2010 | 06:06 PM
  #18 (permalink)
Z28ricer's Avatar
He's been building that thing for around the last 6 years or so, and the how to efi to carb swap your thirdgen should be retitled how to fail, miserably.
Its sad that I could put together a car that would have that 305 pos for lunch using less than $2500.
Dead serious, LT1 or LS1 swap, or you will end up wasting money to get mediocre results.
Old Feb 3, 2010 | 06:13 PM
  #19 (permalink)
J@meson's Avatar
Im not knocking the LT1 or LS1 swap... Just stickin up for the old 305, chevys red headed step child... $ is most peoples problem, But my next car im going to build is a Malibu wagon with a Ls1/T56 combo. My point was done right for 1000$ you can make a 305 slap into the 13's and have people double take... But there is no replacement for a stroked LSX
2003 Honda 954RR
Old Feb 3, 2010 | 07:56 PM
  #20 (permalink)
Z28ricer's Avatar
The thing is now you can literally get a b body LT1 at LKQ, combine this with a cam, and you dont even have a chance to come close with a 305 for the $.
The same $1000 i'd have an LT1, and cam, which would go 12's, as well as have a lot more potential, ya know ?
