V8 S-10 issue???
Old Sep 25, 2009 | 10:56 PM
h4scoobie's Avatar
Question V8 S-10 issue???
Whats going on guy's. I think this is my first posting in the Chebby section. However issues with a toy of mine makes me seek out yuo chevy guy's.
Here is the gist of my issues. I put a 1991 trans am gta l98 350 in my 1999 Hombre (Like s10 just nicer) I installed everything its mated up to a 700r4. Currently its running open headers until I get the cut drive shaft back to make it up to the muffler shop. But the motor is now carb'd and running a holley double pump with a holley street dominator intake manifold.
And now the issue the motor turns right over, But when you rev it up you have a slowly open the thottle, and when it calms down it idles for maybe 2 secs then dies. Any advise would be good on where to look first.
Old Sep 26, 2009 | 01:28 AM
sl2racer's Avatar
is it a new carb? maybe the carb needs to be rebuilt
Old Sep 26, 2009 | 02:21 AM
J@meson's Avatar
Resident Ginger Kid...
didnt that Hombre use to be EFI? If so what are you using as a fuel pump to feed that small block?
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Sep 26, 2009 | 07:54 AM
h4scoobie's Avatar
The complete tank is removed and a fuel cell in the bed, With a mech fuel pump on the engine
Old Sep 26, 2009 | 01:22 PM
.Patrick.'s Avatar
Has twenty valves
could be a vacuum leak.
Old Sep 26, 2009 | 02:02 PM
h4scoobie's Avatar
Ok got it to idle, But still dies and hesitates when given gas. Im thinking the carb may be too bg for the motor? Or needs rebuild?
vacuum is about -15
Fuel pressure stays about 5psi
Old Sep 27, 2009 | 04:36 PM
sl2racer's Avatar
i thought carbs need 15psi
Old Sep 27, 2009 | 05:56 PM
J@meson's Avatar
5-9psi is good... 15psi will blow the needle off the seat in the carb and flood out the motor
2003 Honda 954RR
Old Sep 27, 2009 | 06:02 PM
h4scoobie's Avatar
^^ 15psi the high volume pump only put out roughly 10 psi. Im thinking its the accelerator pumps ill adjust them tomorrow while im installing the drive shaft.
