99 tahoe Brakes dragging?
Old Jun 8, 2009 | 04:08 AM
Paul's Avatar
Motha Fawking Baby Maker
Default 99 tahoe Brakes dragging?
So I got a used 99 2 door tahoe..I have had it for 8 mo's but never taken it on long drives..as its not my DD...I take it out the other day and on I75...get about 20 mins out and it starts to have a bad shake...so I pull over and look to see if I can see any thing...the front passenger side wheel was smoking really bad..so I let it cool off and then take it home "back rd's"..when I get home I pull the wheel off and it looks like the Brake is dragging...so I take the caliper off and ck the sliders..they looked ok so I regressed them anyway..ck the line..it all looked ok...so I took it about again..thinking I had it fixed..about after driving for about 10 mins...same thing again..take it home look it over again...cant see any thing..so I bleed out all 4 sides NEW Clean dot4 and then take it out again...same thing...so next day "today" get a new caliper & rubber line & rebleed out.... every thing looks good and clean...take it out again..same thing again..I am @ a lost with what else it can/might be...thanxs for any help..-Paul
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Jun 22, 2009 | 10:01 AM
Are the self adjusters working as designed, or tightening when they should not?-Bob
Old Jun 28, 2009 | 05:29 AM
Paul's Avatar
Self Adjusters on the front?
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Jul 17, 2009 | 01:56 PM
???'s Avatar
Capt."Howling Mad"Murdock
if you get to the point of trying anything, they do have brake pressure gauges. you could T one to that side and see if that tells you anything.
Old Jul 17, 2009 | 05:34 PM
Paul's Avatar
yah I'm getting tot he point where I'm not sure whats next..
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Aug 10, 2009 | 06:25 AM
???'s Avatar
any updates. did you figure it out?
Old Aug 11, 2009 | 01:51 AM
Paul's Avatar
kinda last min I had to move from Brandon to Tampa...so I drove the tahoe...did ok for a long ways but then was smoking from the drivers side wheels...now this is the other side to the 1st time it was smoking...and the only thing I had not replaced was the rubber line on that side..so when I get the extra time and my tools from my old house I am going to swap that one out and see is that fixs it..
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Aug 11, 2009 | 04:38 AM
If the line can be bled, maybe the rubber brake line is not the problem.
I normally replace brake lines two at a time.
How do you know the caliper is not sticking?-Bob
Old Aug 11, 2009 | 01:50 PM
Paul's Avatar
I replaced both calipers..and if the like is bad it can work like a one way check valve..letting the fluid go one way and not the other...
A2 Element SC
Stock EK9
13 CR-V EL-L
Old Aug 11, 2009 | 02:07 PM
???'s Avatar
haven't you already replaced both lines?
I thought I remember reading that somewhere, if not. deff worth a try.
