What should I run with my 400 V8?
Old Jan 19, 2009 | 11:58 AM
71 Formula's Avatar
Line em' up!
Exclamation What should I run with my 400 V8?
It's a 1971 Pontiac Firebird Formula 400, this is all I have done to the car so far...
Summit Cam and lifter set ( 0.465 int./0.488 exh. lift)
Comp Cams pushrods, valve springs, and retainers
Summit long tube headers
Summit universal X pipe with Summit chambered exhaust
Edelbrock Performer intake manifold
Holley 750 cfb carburetor
Pertronix HEI conversion kit
Summit fuel pump
B&M shift kit (Turbo 350)
Rebuilt limited slip differential with 3.55 gearing.
The car is quick for using E-bay and Summit parts, I was just wondering if you could give me any ideas on what kind of ET I am looking at in this?
And if it helps any the car from the factory made 300hp, and 455 lbs of torque.
I also have a pair of Center Line wheels with M/T Slicks on them.
Anyone have any 1320 guess's for this car?
Old Jan 19, 2009 | 07:31 PM
D Series King's Avatar
After 1970, SAE ratings went into effect. I would say a factory 400 71 would run a 14.00 flat, maybe a little slower if it wasnt tuned right. You should be in the mid to low 13 second range no problem, large CI Pontiac's respond very well to simple bolt ons.
