transmission cable adjustment??
i have a 91 s10 with the 4.3 (OD tranny) which i converted to run off a 600 holley. it runs great. just want to make sure that i adjusted the transmission cable correctly. Any suggestions on this would be appriciated. thanks
i wish that it was that simple, i have been studying up and it gets complecated when one strays from stock. follow the following links to see what i mean:
700R4 Info Page 1
GM TV Cable Adjustment Instructions
the shift points are exact but it doesnt really go into lower gears as it should at wot. i really just dont wanna mess up the tranny.
700R4 Info Page 1
yes, everything else seems fine, shift in range (maybe a couple mph higher before shifting) with the same shifting "tone" as before. but say when i "stomp" it right when it shifs into second it doesnt down shift. any ideas?
well maybe the tv cable is not adjusted correctly. to put it simple you have someone push the gas down, push the release block and slide the cable back to the firewall, then one click more, release pedal and thats that. i just adjusted the one on my monte after rebuilding the trans and its on the money now.
shit i didnt realize he said he was running the 600Holley. Tiffany is right, you will need the correct bracket for the Holley to adjust it properly
also thanks guys for pointing out to me those brackets, I will have a good time fabbing those up
