4.3 timing??
Old Jul 12, 2008 | 12:50 PM
25 to LIFE's Avatar
Exclamation 4.3 timing??
I have a 91 s10 with the 4.3 and wanted to clarify a couple of things. The timing is based on the #1 cylinder, right? I just ask because there are two timing marks on the harmonic balancer, speaking of which, which mark should be used for timing? I plan to get the compression stroke up on #1 to verify which is the correct mark but I believe it to be the one which is to the left when looking at the two when there in the closest position to each other. just did a carb swap with an HEI dist. i just need to get the timing right now. i think that i need to reset the dist. because i might be off a couple teeth. of course in the middle of this swap gas went up to $4+ p/gal. thanks for any help given.
Old Jul 13, 2008 | 07:29 AM
TURACE24's Avatar
based on number 1 turn the engine to TDC on the number one cylinder and see which mark on the crank aligns with the pointer.
We can always choose to percieve things in life differently. It's important to focus more on what's right in life.. versus what is wrong.
