LS1 question
Old Apr 21, 2008 | 04:00 AM
asia989's Avatar
Why So Serious?
Default LS1 question
How much of a pain would it be to drop into a 92 silverado?
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Apr 21, 2008 | 08:16 AM
Superluminal's Avatar
The Cyber Brain
You might get some back pain, but that's nothing some Advil can't clear up.
Old Apr 21, 2008 | 09:06 AM
Country Boy's Avatar
can survive...
Anything can be made to fit with enough work. The LS1 motor mounts are in a different position and will need a tranny X-member and all accessories and PCM, but its doable.
Old Apr 21, 2008 | 09:58 AM
TURACE24's Avatar
+1 on the conversion mounts. Best way to go, is with a donor car, a totalled out trans-am or camaro, and swap the motor, wiring harness and whole nine yards out. Otherwise, you're asking for alot of un-needed work and nightmares.
We can always choose to percieve things in life differently. It's important to focus more on what's right in life.. versus what is wrong.
Old Apr 21, 2008 | 03:28 PM
J@meson's Avatar
Resident Ginger Kid...
Full-Size Chevy - Main Index it happens more then u think
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Apr 29, 2008 | 09:44 AM
DANGERANGER's Avatar
Shop Bitch
I use the conversion mounts that adapt over and use stock GM SBC mounts and put it in right location. Use shorty headers for Camaro. If your truck was originally an O/D auto you shouldnt need a trans xmember. If you have the stock camaro/vette harness $500 will turn it into a stand alone harness, or buy a new one for a $1000 or less. Electric fans a must, better drop in fuel pump, fuel line adapters, Intake filter of some sort, etc.
Old Apr 29, 2008 | 11:59 AM
J@meson's Avatar
in late 93 they started using the 4l60E in the silverados. early 93 and back was TH400, TH350, and 700R4 which he most likely has the 700R4
2003 Honda 954RR
Old Apr 30, 2008 | 01:10 AM
asia989's Avatar
Why So Serious?
i think its a th350 but im not quite sure, im trying to source a 350 5.7 for it but if i find a ls1 ill go that route
Old Apr 30, 2008 | 05:46 AM
TURACE24's Avatar
probably not a TH350... what does the pan look like on it?
Old Apr 30, 2008 | 10:35 AM
asia989's Avatar
Why So Serious?
short rectangle
