so while changing the exhaust manifold
Old Feb 23, 2008 | 06:36 AM
Bowtie's Avatar
is sorta fast
Default so while changing the exhaust manifold
i discovered that the person who had replaced it before me had cross threaded the bolt and now me and my dad are trying to remove it.. my dad said that we are going to have to tap the block, i have no idea how to do that, We have the bolt down to a shell and the inside completely drilled out.... and now i found out that advance auto parts sold me the wrong bolt... Advance FTMFL!!!
Project Snowsled
Powered by LT1
Monroe/ Belltech Suspension
2.5" True Duals with Flowmaster 40's
Built 700R4 By: Tim Moye Transmission
CSR Electric Waterpump
Old Feb 24, 2008 | 09:49 AM
Sneakin Deacon's Avatar
PSSHHH x2
......why are you tapping/coiling the block when its your head with the loose bolt.
if you can do it in the car, wonderful...but i would pull the head, drill the hole while not hitting a water jacket, and then helicoil it and be done with it.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Feb 28, 2008 | 09:22 PM
BLUE2KSS's Avatar
Mechanical Engineer
+1
