Good Deal?
Ill f@cking end you!
on
Good Deal?
I was gonna put this in Cars FS/Wanted but it seems its better to think of it this way in GM Tech. So I want to buy this car but I need to build up one hell of an argument. I'm trying to get the carfax on it now in the General Car Chat. I've always wanted a 98-02 Z28, but couldn't afford one that would live at all past a couple months lol. This would be about an hour ride for me to check it out in person. I want to know if you think its worth it.
Has approx. 127k, but only 6k on a rebuilt engine.
98 Camaro Z28 LS1 - 423 HP, 550 HP with Nitrous - $8200
1998 Camaro Z28 LS1:
BODY:
- ELECTRIC BLUE CORVETTE PAINT JOB, APPROX 6 MONTHS AGO
- CHROME 16X18: GM PERFORMANCE RIMS
- LIMO WINDOW TINT
- PIONEER AM/FM CD PLAYER
- NEW FRONT CAMARO GRILLE
- SUNOCO COWL 3 IN RACE PERFORMANCE HOOD (ALSO HAVE THE ORIGINAL HOOD!!)
- NEW FOG LAMPS
- NEW FRONT AND REAR TIRES
- NEW BRAKES !!/ ROTORS – ALL 4 WHEELS, CALIPER BOLT PIN SET
- NEW METALLIC GLOSS BRAKE PADS
- NEW T-TOP CHARCOAL SHADES
- NEWLY WRAPPED SUN VISORS
- NEW A-PILLAR POD
- NEW MECHANICAL NITROUS GAUGE / AIR-FUEL / OIL PRESSURE GAUGE SET WITH CAMARO MOUNT
- LEATHER AND INTERIOR CLEAN
ENGINE / HIGH PERFORMANCE PARTS:
- SLP SHORT-THROW SHIFTER
- NEW SPEC-3 RACING CLUTCH
- NEW ALUMINUM PLATED FLYWHEEL
- NEW PRESSURE PLATE
- NEW SLAVE CYLINDER
- NEW SLP LID INTAKE
- LS6 INTAKE MANIFOLD
- PORTED/POLISHED LS1 HEADS
- NEW / UPGRADED CAMSHAFT: COMP CAM 224/224 112 LSA
- 42LB FORD RACING INJECTORS
- RACETRONIX 255LTR FUEL PUMP KIT WITH WIRING HARNESS
- PACESETTER LONGTUBE HEADERS
- BORLA CUSTOM CUSTOM X-PIPE EXHAUST
- TRUEDUALS WITH 1 CHAMBER FLOWMASTERS WITH 90 DEG. TURNDOWNS
- MSD NITROUS ACTIVATION WINDOW SWITCH FROM 3200-6400 RPM’S
- N.O.S. DRY KIT NITROUS SYSTEM WITH 100 SHOT PILL (ENGINE IS BUILT TO HOLD 150 SHOT); ( I ALSO HAVE THE 150 PILL, AND THE 200 PILL SET.)
- NEW A/C SYSTEM INCLUDING AC COMPRESSOR/EVAPORATOR/CONDENSOR/COMPLETE SYSTEM EVAP & RECHARGE WITH NEW ORFICE TUBE & ACCUMULATOR, HOSE (BLOWS ICE-COLD)!!
- FORGED INTERNALS WITH DIAMOND PISTONS
- NEW WATER PUMP AND RADIATOR
- COMP CAMS 918 SPRINGS SET FOR CAM
COMPLETE ENGINE REBUILD DONE AT 121,000 MILES
- COMPLETE GASKET KIT WITH ALL SEALS
- COMPLETE HEAD-BOLT KIT
- COMPLETE MAIN-BOLD KIT
- LS6 OIL PUMP
- TIMING CHAIN / GEARS
- CRANK BALANCER BOLT
- ROD BEARING SET
- MAIN BEARING SET
- CAM BEARING SET
- PISTON RING SET (OEM PERFORMANCE)
- CONNECTING ROD
- LS1 PREPARED STOCK CRANK
- HONE CYLINDER AND INSTALLED CAM BEARING SET
Will also get:
STOCK WIRING HARNESS, N.O.S. PILLS, TUBES, BLOWOUT / PURGE VALVE, NGK PLUGS – FLARE JETS, STOCK CAMSHAFT, STOCK HOOD, GEAR SHIFTERS (HURST HANDLE), AND MANY OTHER MISC ITEMS.
Tons of pics.
http://i84.photobucket.com/albums/k2.../IMAGE_016.jpg
http://i84.photobucket.com/albums/k2.../ls1corner.jpg
http://i84.photobucket.com/albums/k2...r/DSC03024.jpg
http://i84.photobucket.com/albums/k2...r/DSC02982.jpg
http://i84.photobucket.com/albums/k2...ster/blue2.jpg
http://i84.photobucket.com/albums/k2...er/blueint.jpg
http://i84.photobucket.com/albums/k2...oster/blu3.jpg
http://i84.photobucket.com/albums/k2...311111_081.jpg
http://i84.photobucket.com/albums/k2...311111_080.jpg
http://i84.photobucket.com/albums/k2...r/P1130063.jpg
http://i84.photobucket.com/albums/k2...r/P1130062.jpg
http://i84.photobucket.com/albums/k2...r/P1130061.jpg
http://i84.photobucket.com/albums/k2...r/P1130059.jpg
http://i84.photobucket.com/albums/k2...r/P1130060.jpg
http://i84.photobucket.com/albums/k2...r/P1130058.jpg
http://i84.photobucket.com/albums/k2...r/P1130056.jpg
http://i84.photobucket.com/albums/k2...r/P1130052.jpg
http://i84.photobucket.com/albums/k2...r/P1130053.jpg
http://i84.photobucket.com/albums/k2...r/P1130054.jpg
http://i84.photobucket.com/albums/k2...r/P1130043.jpg
http://i84.photobucket.com/albums/k2...r/P1130044.jpg
http://i84.photobucket.com/albums/k2...r/P1130046.jpg
Any opinions would be nice.
Thanks for the input.
-DK-
BODY:
- LIMO WINDOW TINT
- NEW FOG LAMPS
- NEW A-PILLAR POD
- LS6 OIL PUMP
- ROD BEARING SET
- MAIN BEARING SET
- CAM BEARING SET
- CONNECTING ROD
Will also get:
Tons of pics.
-DK-
Ricer: From the latin word Ricarius meaning to suck at everything you attempt!
AIM = donkeyk1989
XBOX Gamertag = DK1989
Myspace.com/donkey_kong1989
DK for Mod since people care
Parris Island here I come =D!
AIM = donkeyk1989
on
No opinions apparently.
AIM = donkeyk1989
AIM = donkeyk1989
on
I looked into it more from a link someone here sent me and the dudes a nice guy but its all a lie. It doesn't have all these mods, its not making this power, and its been in 2 accidents.
AIM = donkeyk1989
AIM = donkeyk1989
on
Cool thanks for all the input guys.
AIM = donkeyk1989
AIM = donkeyk1989
on
^ haha heres the link but be for warned I've had 3 people now tell me its a ripoff.
1998 Camaro Z28 LS1 - 423 HP / 550 HP with Nitrous...
AIM = donkeyk1989
AIM = donkeyk1989
I would definitely be worth it if it had the power and those mods. If not plus 2 accidents move on thats probably where the new hood came from and who knows what else is wrong with it then.
