s/c 3800 into a 95 Noma?
Old Dec 2, 2007 | 04:55 PM
Mars_302's Avatar
Race Photographer
he has a 2.2, which makes any swap pretty hard to do
Old Dec 2, 2007 | 06:27 PM
J@meson's Avatar
Resident Ginger Kid...
Originally Posted by IThaJokaI
Exactly why I dont have a 350. I can get a 350 thats built with dyno proven 380 hp for $600 But I dont want just another sb-s10. I know the TB will be facing the wrong way, but if it fits, its as simple as a custom intake( will hit a shop for an aluminum one) I would find a RWD tranny that bolts to it, like the one from a GNX(just an example.) Im just wandering if the mounts will fit the trans, I dont really want to have to weld up new mounts.
GNX, GN, T-type, 442, Monte carlo SS etc have all the same 200R4 tranny. will not bolt up to the 3800 sc as its a different motor from the 3.8 that came in the chevys and buicks. buicks use a BOP bolt pattern and that tranny is cast in SBC and BOP bolt pattern. neither will work for you.
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old Dec 3, 2007 | 06:02 PM
swenson13x's Avatar
To an extent there is still about the same amount of room just more shit to move when you do the swap and if he has a 2.2 the 4.3 would be a great swap.
To the person with the truck what are u looking for in this truck? speed or power? just wondering.
Old Dec 4, 2007 | 07:03 AM
IThaJokaI's Avatar
Hates cars...
I am debating bagging the truck, giving it just more power than it has. I dont want a dyno queen nor a full on race truck. The 4.3 would be an ok swap, but I think Im pretty much stock on the 3800. As for room, cuttung fender linings and the such wont be a problem because as I said I plan on bagging it.
So really to answer your question I want a semi-powerful motor that is more reliable that boosting-s/c the current 2.2L.
-Mike
Old Dec 4, 2007 | 09:03 AM
J@meson's Avatar
dont forget gm turbo'd the 4.3 in the syclone and typhoon motors and fitted with AWD those things ran deep into the 10-11's. hell they ran low 13's under stock boost. id look into doing a turbo 4.3
2003 Honda 954RR
Old Dec 5, 2007 | 04:31 PM
swenson13x's Avatar
A turbo is always the way to go not super charged, the 4.3 would be good but for cheap the 2.2 with forged pistons, total rebuild, a T3 35r turbo and a new set of injectors, with an 8,000 rpm rev limiter wounld give you amazing power for cheap. i have a 2.2 and pistons cost $300, cam was $300, Turbo kit was $2000. a 4.3 should be around the same cose for you but you will have to add cost for motor, tranny and mounts.
Old Dec 6, 2007 | 04:45 PM
  #17 (permalink)
swenson13x's Avatar
And also with keeping ur 2.2 you wont have all the little things to change, you have more room to work with and you will get better mpg.
