need 350 tranny help?????????
Old Nov 4, 2007 | 02:19 PM
nisson93's Avatar
Default need 350 tranny help?????????
ok i have and older 350 don't know the year don't know if it is roller or not the ? is i want to put a five speed tranny on it what tranny would i need and i don't not want to do any serious moding to the motor so what im asking is for a stock tranny for the 350 also would a ls1 t56 tranny fit the engine
and if anybody has one ill take it thanks
Old Nov 5, 2007 | 02:55 AM
Sneakin Deacon's Avatar
PSSHHH x2
The T5's from a V8 will fit...like a camaro/trans am/firebird of the 80's. should be able to find one really easily at a junk yard. just make sure its from an engine with corresponding rear main seal.
with that, you will need the flywheel, pressure plate, clutch, bell housing, hydraulics, shifter, and a clutch alignment tool and pedal assembly if ya dont already have it.
also the LS1 T56 will be a bit more complicated to make fit, but the LT1 T56 which is practically indentical will be better as it bolts right up without a housing adapter. the only thing that will come into play is, again, the rear main seal. if you have a 1pc, then you will be fine, if you have a 2pc, you will need the conversion flywheel from centerforce to be able to use a T56 on a 2pc rear main block: Centerforce Steel Flywheels: CTF-700107 - summitracing.com
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Nov 5, 2007 | 08:00 AM
nisson93's Avatar
Old Nov 5, 2007 | 08:07 AM
Suicidal Racing's Avatar
Has V.I.P in HELL!
kenny nailed it on the head man.
Old Nov 5, 2007 | 09:54 AM
nisson93's Avatar
ok guys thank you alot just so you kno im putting the 350 after i funish building it in a 240 thanks for the help
Old Nov 5, 2007 | 10:58 AM
Has V.I.P in HELL!
you have a pm back.
whats your hp goals for this engine?
Old Nov 5, 2007 | 11:14 AM
nisson93's Avatar
more a tourqe goal i need it to shit side ways i done a lot of work on 350 for circle track racing bc my dad races sportmans and he makes insane power but also insane money im kinda doing this all by myself and ill keep u all posted
