700R4 Rebuild
Old Sep 21, 2007 | 10:56 AM
Bowtie's Avatar
is sorta fast
Default 700R4 Rebuild
ok so im getting my transmission rebuilt soon and its gonna cost me 1500.00 so is there anything i should get done under there while i can?
Project Snowsled
Powered by LT1
Monroe/ Belltech Suspension
2.5" True Duals with Flowmaster 40's
Built 700R4 By: Tim Moye Transmission
CSR Electric Waterpump
Old Sep 21, 2007 | 12:28 PM
jw34689's Avatar
Zero By Default
Damn u can buy a built one for cheaper then that. Maddog transmission i think there in tampa now they sold one rated for 500+ hp for i think for like $1200
2. When questioned by a friend's girlfriend, you need not and should not provide any information as to his whereabouts. You are even permitted to deny his very existence.
37. Before allowing a drunken friend to cheat on his girl, you must attempt one intervention. If he can get up on his feet, look you in the eye, and deliver a "fuck off" then you are absolved from all responsibility.
Old Sep 21, 2007 | 12:31 PM
jw34689's Avatar
Zero By Default
ebay is your friend ..there in Tarpon good shop..eBay Motors: Chevy GM 700R4 4l60 Transmission 2wd 4x4 car,truck (item 200152703254 end time Sep-24-07 07:37:34 PDT)
Old Sep 21, 2007 | 12:36 PM
Bowtie's Avatar
is sorta fast
i know but my dad will not let me spend my money anywhere else except quality car automotive i cannot convince him at all
Project Snowsled
Powered by LT1
Old Sep 21, 2007 | 07:29 PM
Sneakin Deacon's Avatar
PSSHHH x2
what is this going into?
you could get a shift kit put in, hardened sungear shell, etc. if this is a tranny that will see some abuse. even if it wont, i always recommend an external tranny cooler, bar/plate style.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 21, 2007 | 07:55 PM
jw34689's Avatar
Zero By Default
1+
Old Sep 21, 2007 | 07:59 PM
SmokinS13SR20's Avatar
That ginger...
This man knows what he's talking about when it comes to transmissions, well shit...almost anything...
Old Sep 22, 2007 | 05:27 AM
Bowtie's Avatar
is sorta fast
this is going into a suburban... and i planned on getting an external tranny cooler. is there a difference without one? because ive never had one before
Project Snowsled
Powered by LT1
Old Sep 22, 2007 | 08:43 AM
PSSHHH x2
basically the biggest reason for having auto trannies go bad, is overheating. im guessing this is sitting behind a big block, and it has alot of weight to push around, so heat will be there. Just run the stock cooler into an aftermarket, like a B&M 24kGVW bar and plate cooler, and then back to the tranny, and you should be just fine as far as overheating the fluid goes. you may or may not find benefit from a shift kit, like a transgo kit, to firm up your shifts. the added vein pressures will reduce slipping of the clutch bands and also reduce heat aswell.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 22, 2007 | 08:15 PM
Bowtie's Avatar
is sorta fast
thanks man i really appreciate because that sounds like something i need.
Project Snowsled
Powered by LT1
