'97 Pontiac Sunfire horn issues.
I have a '97 Pontiac Sunfire the horn will go off at random times during the day. The only way to stop it is to pull the fuse, which is also the fuse for the power outlet. The horn button on the right side is very sensitive, i can just graze my finger over it and it will go off so this may be causing it. Any ideas on how to fix this?
could be one of three things either a bad realy or the horn button in the wheel hasissues you going to have to wait till it acts up. do you know how to use a test light there is a black wire comming done the colum it like 14ga test it see if is grounded you are going to hook the wire with clap to12volt in orger to test for ground let me know i can walk you through it todd
