supercharger ?'s
Old Jun 4, 2006 | 07:26 PM
Pennywise's Avatar
why so serious????
Default supercharger ?'s
well i might be buyin a paxton from a buddy of mine, its only the backet and head unit and piping, i was wondering what else i would need...i kno i need the box that covers the carb for the air from the supercharger..but what about fuel pressure and stuff like that...the motor is a 1st gen 350...it came out of a old blazer its still pretty much stock..any advice would be helpful.
thanks,
steven
Cornbread Crew member #754
Old Jun 5, 2006 | 10:18 AM
myltwon's Avatar
Bolt-On 2v GT
colder plugs, random ignition upgrades, bigger carb, hd fuel pump....uhhhh
Old Jun 5, 2006 | 11:58 AM
theorangeguy's Avatar
gauges for the boost, wiring, some internal stuff wouldnt hurt...but you dont have to do it.
Ignition upgrades, plugs, and the fuel pump are probably the key things.
Old Jun 5, 2006 | 04:58 PM
Pennywise's Avatar
why so serious????
well, its already got MSD so...i guess just plugs and better fuel pump then..where can i get the box to cover the carb and what plugs would work best?
Old Jun 5, 2006 | 08:12 PM
C4_crusin's Avatar
150+ in the emergencylane
make sure you get good belts. what kind of blower(paxton is the sister company of vortech) and make sure it lets the boost blow back through unless you have a bov, keeping the impellar speed reasonable will insure it doesnt come apart.........what kind of motor?
superchargers are a pain in the ass, but once its up and running its usually ok. getting all the bugs worked out is the hard part.
here are some of the mods I had to do (i'm fuel injected though):
areomotive1300 fuel pump
fuel lines 12 feed 10 return
modified fuel rail
injectors
3 different pressure regulators
fuel pressure guage
boost guage
timing retard module
mine had an intercooler with a stupid valve (it got removed)
mas air sensor
i still have to get rid of the rubber hoses that baloon up under boost. getting a bigger blower cause the belt slip is stopping my hp development, and its hard to tune properly when you get a different amount of boost every pull.
D-1SC procharger f/s $2500 with injectors and TPIS fuel rail, <1000miles
AIM:gsxrpat76
Old Jun 5, 2006 | 08:51 PM
myltwon's Avatar
Bolt-On 2v GT
4th gen guys love .035-.040 gapped ngk tr6's for n2o and f/i not sure what a gen I sbc favors though
Old Jun 6, 2006 | 06:45 AM
Pennywise's Avatar
why so serious????
modified fuel rail
injectors
fuel pressure guage
boost guage
mas air sensor
yea, i am not gunna push much boost...the motor has alot of aftermarket stuff on it...i think everything will be ok,the only thing i am gunna replace is the fuel pump...
Old Jun 6, 2006 | 07:04 AM
C4_crusin's Avatar
good luck!
i'm selling my procharger D-1SC its barely used.
AIM:gsxrpat76
