3rd times the charm right?
well this is on engine rebuild number 3.... So lets see if we can not spin a bearing this time.. and what the real cause of the 1st two were.....
But at least this gives me an excuse to mod it a bit more...
Getting a matching set of LE heads & Joe Overtons custom grind cam. Hopefully you cant go wrong with the guy who has the fastest NA LT1 in the country.
Should run really stong NA... Engine will be setup for NA but with consideration of future nitrous if i feel the need.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
Dom I will kill you...
Ah i couldnt sell that car eddie.. doesnt matter how many it spins.. I'll just scrape the whole block and start over.. Steve's doing it this time and he hasnt lost 1 yet so i have a bit more faith..
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
Sucks man, been there with constant engine trouble before. Are you priming the motor with oil before you crank it?(by using that drill tool to spin the oil pump)
448WHP/420WTQ
Full bolt-ons+H/C
Car Sound Clip & More(W/ Mekanic)
Tuned by Precision Motorsports
448WHP/420WTQ
Full bolt-ons+H/C
well if you want a set of nicely worked heads, and a new bottom end, lemme know.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Yep primed... Im thinking that the eagle cranks oil relief holes may be the problem.. I kinda find it hard to believe that the last machine shop would machine shit wrong.. its more probably that they didnt check the crank that well because it was new and suppose to be fine..
I have some bad ass heads already kenny... Just need the bottom end to work right and keep it forged for that future just incase shot.
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
