Transmission/Rear Questions...
Originally Posted by gator
hello capt obvious. so whats your thought on this? you then believe a 2500-2800 convertor best matches to the power curve of your motor?
because i know it isnt.
i bet you are going to start talking about peak tq numbers lol.
they have nothing to do with picking the right convertor.
im am going to be putting a 3500 stall in my car to run on the street. is this too much stall for the street? also have newer posi center section with 355 gear goin in as well. car is a 79 malibu with a 355 vortec motor,700r4 with shift kit, stock 2200 stall. good or bad idea with that stall
Alex, This isn't about you anymore, Now you're ANSWERING questions.......did you ever get your answer...Oh and I'm not going with a 3000 anymore, I'm picking up that stall from Sneakin Deacon.....still better than the stock converter
ah you bastard I was gonna buy it!
but on another note if you change your mind, there is a guy in spring hill who sells
2800 stalls on ebay for $150 if you wanna see if he'll sell one offline to you
150 dollar stall on ebay? lol, go for it. they make awesome weight ballast. you fellas that are considering this need to do some reasearch. you are buying a used truck convertor repainted (maybe).
or afterwards, lets hit the track and i will give ya a "i told ya so"
but its your decision. i like to spend money to go quicker and faster.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
also here is my .015
no such answer for "is this stall too big for the street"
no such answer for "is this stall good for my combo"
if you are basing it on a number of theoretical flash stall.
also if you are looking for cam duration and lobe seperation angle values at .050" valve lift to determine where peak power is made - lol. might as well use the old throw a dart at it method.
my cam values, shift point, and convertor flash point are all against these ideals.
but it works pretty decent for a street car.
I could understand wanting to save money by purchasing Pacesetter headers over Kooks.
But do it with a converter and you wont be very happy.
Actually, I shouldnt say that. Maybe you will be happy. but that is only because you have no idea what GOOD converter would have done.
actually I know someone that purchased the same convertor, from the same seller and had great results with his
sorry but $700+ stalls are out of my budget, I was hoping to try it out, if it sucks, oh well I'm $150 poorer
150 dollar stall on ebay? lol, go for it. they make awesome weight ballast. you fellas that are considering this need to do some reasearch. you are buying a used truck convertor repainted (maybe). .
IMO 2800 wouldn't be the optimal stall speed for maxium acceleration, however, factoring in that this car is daily driven, it's a good choice imo. Not everyone's goal is to go as absolutely fast as possible... he just wants more getup off the line without sacraficing daily drivability, and I think that's very wise.
-Vince
-Vince
