0-140 vid
First WOT runs from 0-140 short shifting at 7000 rpm or so. Just testing a bit and cautiously rowing the gears. The clutch needs to be bled bad. At 7700 in 4th gear its 156 mph. I need to take the VC's off and check the top end again and check a few things out...but it seems to be ready to go down the strip. I need to hook up the Autometer tach so I know exactly what RPM I am spinning to. The stock tach lags sooo bad.
Hopefully will be out there Sunday bright and early.
Not much to see in the vid...but you can hear good
Click here to see Video
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
I wish I could view it, for some reason it only plays the first five seconds of the video. Do you have another host or anything? I want to see it!
RIP Kevin C. Gonzalez; Miss You Brother.
just try again in a few minutes. It should load all the way. That site is really bogging down LS1tech.com. The whole site has been slow and error prone. They are workin on it. There are several people also several peeps DL it right now.
lol...the speedo is correct...but that doesnt matter...go by the rpm and the tire size. If I were to top out that 4th gear to 7700 rpm I would be going close to 160. I was likely only around 6700 rpm in 4th...you can tell I didnt spin it up too far. 6700 rpm x 28.5 tire with my rear gear in 4th =140 mph. The speedo is slow to respond.
Either way its a guess. 138-140-142.....doesnt mean much till I go to the track. But its somewhere around 140.
FYI...first gear alone is about 55 mph
Originally Posted by Datruth
Must be nice to be fast.
glad to see shes up and running good. can't wait to see it on the track.
R.I.P Dad.
The greatest man I've ever known.
6/14/43 - 7/11/06 2:24am
R.I.P Dad.
hahaha...the diesel truck vid on there kicks ass!!
Marisela
Marisela
“Meditation brings wisdom; lack of mediation leaves ignorance.
Know well what leads you forward and what holds you back, and choose the path that leads to wisdom.”
~ Buddha ~
~ Buddha ~
